      Mar 2013
      Country Flag: Belgium
      Carburated engine return line
      Not sure where to post this since its not an EFI.
      Running a carburated 408( well should be when it arrives in a few weeks)
      Stock fuel tank with external electrical fuel pump from holley
      Got filters, pressure regulator and a return line in place.
      Question is, where do i best install my return line?
      My fuel tank has a drain plug so i was thinking to connect my return on the drain plug.
      (Just not sure if this might cause an issue?)
      What are your thoughts?
      Thanks!
      Apr 2012
      Woodstock, IL
      The higher the better so the fuel has an unrestricted path.
      -Dale
      SchwartzPerformance
      Jun 2006
      Katy,TX
      Get rid of that glass filter! They crack and leak.
      1965 GTO project car
      2004 Pulse Red GTO
      Mar 2013
      Quote Originally Posted by Skip Fix View Post
      Thanks for the heads up
      Oct 2015
      Return line to the top of the tank if possible, X2 on the glass filter asking for trouble, return line should prevent vapor lock.
      Just checking... you have a "bypass" regulator, correct?
      SMSgt Ty Ingle, USAF
      "CF71" - Freedom Bird
      Central CA USA
      You could tap or weld a bung low on the filler neck.
      Mar 2013
      Quote Originally Posted by OLDFLM View Post
      This is the one i have:
      https://www.holley.com/products/fuel...s/parts/12-881
      - - - Updated - - -
      Quote Originally Posted by David Pozzi View Post
      Was thinking about doing it that way, saves me the issues of dirt getting in my fuel tank when drilling a hole into it..
