    Results 1 to 20 of 26
      Sep 2012
      Country Flag: Ireland
      LS3 Cam Selection
      Hi Guys,
      Just working on the shopping list for the new LS3 swap into my '73 TransAm and wanted to get your advice on the best cam to use. My builder is suggesting the use of the CompCams Hydraulic Roller 146-460-11 LSR. Anyone got any real hand experience of this in an LS3?
      Shopping list below ( tax man here in Europe will be happy with this! )
      Part Link Cost
      Pistons https://www.summitracing.com/int/parts/man-596265c-8/make/chevrolet $793.99
      Main Bearings https://www.summitracing.com/int/parts/cle-ms2199h $136.99
      Rod Bearings https://www.summitracing.com/int/parts/cle-cb663hnk $17.99
      Camshaft https://www.summitracing.com/int/parts/cca-54-460-11 $389.99
      Roller Lifters https://www.summitracing.com/int/parts/cca-15956-16 $544.99
      Pushrods https://www.summitracing.com/int/parts/cca-7955-16 $140.99
      Rockers https://www.summitracing.com/int/parts/cca-19028-16 $524.99
      Valve Covers https://www.summitracing.com/int/parts/hly-241-402 $279.95
      Head Gaskets https://www.summitracing.com/int/parts/nal-19170419 $152.00
      Head Bolts https://www.summitracing.com/int/parts/arp-134-3610 $101.99
      Headers https://www.summitracing.com/int/parts/hed-45123 $696.99
      Starter https://www.summitracing.com/int/parts/pwm-9509 $217.99
      Water Pump https://www.summitracing.com/int/parts/mor-63566 $476.99
      Plug Leads https://www.summitracing.com/int/parts/acc-9070c $110.95
      Oil Filter https://www.summitracing.com/int/parts/nal-12626224 $15.99
      Spark Plugs https://www.summitracing.com/int/parts/ado-41-101 $55.92
      Fluid Damper https://www.summitracing.com/int/parts/ati-918628 $436.00
      Clutch https://www.summitracing.com/int/parts/acl-t2r-g05/overview/model/acl $1,060.00
      EFI System https://www.summitracing.com/int/parts/fif-72213 $2,140.00
      Radiator https://www.summitracing.com/int/parts/bci-10010 $329.99
      Wiring Harness https://www.summitracing.com/int/parts/prf-20112 $949.99
      AN Fitting's/Plumbing Fuel, Brakes, Coolant, Power
      Propshaft
      Stainless Exhaust System
      Hardware/bolts/nuts/washers/rivnuts/cable ties/
      Mufflers https://www.summitracing.com/int/parts/flo-8043041 $179.90
      Rear Axel & Pinion Gearing https://www.summitracing.com/int/parts/yga-24161 $309.40
      Front Disc Brakes https://www.summitracing.com/int/parts/wil-140-10738-dr $1,074.99
      Rear Disc Brakes https://www.summitracing.com/int/parts/wil-140-9315-dr $864.99
      Brake Booster https://www.summitracing.com/int/parts/sum-760166 $137.99
      Master Cylinder https://www.summitracing.com/int/parts/ssb-a0469-5 $395.99
      POWDERCOATED HYDROFORMED SUBFRAME - (1970-81 CAMARO / FIREBIRD - SINGLE ADJUSTABLE SHOCKS - SBC / LS) https://www.detroitspeed.com/powderc...d-032014-group $8,684.00
      DETROIT SPEED, INC. QUADRALINK™ REAR SUSPENSION KIT - (1970-81 FIREBIRD - SINGLE ADJUSTABLE SHOCKS) https://www.detroitspeed.com/detroit...d-041714-group $3,380.00
      Subframe Connectors http://www.globalwest.net/1970-1971-...obal-west.html $259.95
      LS Swap Kit? $1,995.00
      Electric Fans https://www.summitracing.com/int/parts/spu-ix-30102049 $303.12
      Power Steering Pump https://www.summitracing.com/int/parts/hly-198-100 $294.00
      Power Steering Tank https://www.summitracing.com/int/parts/mor-63788 $135.99
      Power Steering Pulley https://www.alpermotorsports.com/index.php?l=product_detail&p=181 $94.00
      Clutch Pedal Conversion https://www.classicindustries.com/product/1973/pontiac/firebird/parts/kw328.html $89.98
      Master Cylinder Kit https://www.summitracing.com/int/parts/awr-hmgm30001sr $403.99
      Slave Cylinder https://www.summitracing.com/int/parts/nal-24237634 $194.99
      Stealth Fuel System https://www.summitracing.com/int/parts/aei-17168 $1,177.00
      Air Filter https://www.summitracing.com/int/parts/knn-ru-3102hbk $60.99
      Shifter https://www.summitracing.com/int/parts/baa-2010bc-2bv8 $285.00
      Air Con System https://www.vintageair.com/surefit/complete-kits/?make=Pontiac&year1=1973&model=Firebird $1,480.00
      CVF LS Engine Serpentine Kit https://www.cvfracing.com/chevy-ls-engine-serpentine-kit-ac-alternator-power-steering/
      Electric Cut-outs
      Electric Window Kits https://www.mattsclassicbowties.com/...ndow_Kits.html
      Glass Set https://www.classicindustries.com/product/all-years/pontiac/firebird/parts/*e355t.html $627.00
      Bonnett Hinges https://www.mattsclassicbowties.com/contents/en-us/d2319.html
      Wheels
      $4,700.00
      Body bushings solid, rubber or poly
      $36,702.95
      I guess the first thing I would want to know is the compression ration, and the second thing would be how the car is going to be used. The cam that your builder suggesting is pretty wild, personally I would never use it in a street car, but people's tolerance for big cams vary quite a bit. I tend to like milder cams because they make for a nicer driving car and are easier to tune.
      For what it's worth, a friend of mine purchased the LS3/430, then added the BTR racing Stage 2 LS3 cam with the suggested valve springs and pushrods. The engine is installed in a 1966 Farilane and weighs about 3900 pounds. The car has run a best of 11.65 at the drag strip. It is a beast, and drives really nice.
      Sep 2012
      I always liked a bit of wild!
      Its calculating out at 11.57:1 at the moment... its got 821 heads on the block.
      I guess its all about the brief.... told him I wanted something with lots of power, but something that I could equally drive long distances to shows without having a massive headache!
      Its initial figures at the moment - but getting feedback from others is all part of the process and trying to get a sense if it is just a bit "too much".
      For me, it is definitely too much, but others may have different opinions.
      Mar 2013
      Napier, New Zealand
      Country Flag: New Zealand
      I have that exact camshaft on my 408.
      Its awesome, accelerates very hard
      Damien
      Napier, New Zealand
      Project Page: https://www.pro-touring.com/showthread.php?99096-Project-Camaro-68-P-T-Muscle
      Next Project: 1956 Chevy Truck, Full C3 Suspension, Nascar Inspired
      Quote Originally Posted by Tweak View Post
      A 408 is not a 6.2L...lol
      Displacement plays a big role on a cam behavior.
      OP, what is the max rpm that you plan on shifting? Are your heads ported or stock (do you have the head flow values)? What's your transmission are you using (hopefully it has overdrive with those 4.56 rear gears)?
      Pensacola, FL
      I agree it's a tad on the radical side. If you end up sticking with that fitech system, I'd definitely go smaller on the cam. I have not run one personally, but know guys that have and the ones with big cams had some annoying issues. With that intake & cam, it will want some gear- at least 3.90/4.10 range. What trans are you running? I would personally step it down just a bit. I'd rather see you CNC port the heads and go with something closer to a stage 2 cam. I'm really picky about driveability though.
      Sep 2012
      I guess there's no right nor wrong... it would be great to drive the car with the two cam options and decide, but in the absence of that I'm just going to have to decide a route. When you say you think its too much, do you mean from a drive-ability perspective? It would be really useful to know the cons of such a cam with regards driveability (not sure what a cam like that does to idle etc).
      Sep 2012
      Quote Originally Posted by 68Formula View Post
      Good question... I'm not really going to be driving this at the top-end, so low-down grunt & acceleration are the primary points. Shifting RPM, havent really thought of that to be honest - but like I said this isnt a track-day car, something more with the "wow" factor that I'll drive weekends and take to shows. I'm guessing max shifting RPM is going to be the 6,000-6,500 range. Heads will be stock, and I've purchased a new Tremec TR6060 transmission for the build.
      Sep 2012
      Quote Originally Posted by Z06vet View Post
      What's wrong with Radical??
      Not stuck on the Fitech system. In fact, wanted to run the Edelbrock LS3 Crossram intake but builder reckons we will need a different system to drive those twin throttle bodies. I'm in Ireland, so CNC porting these type of heads isnt something thats readily available - I'd probably have to ship to the UK to get that done. Noted the transmission below (new Tremec TR6060). I am a bit concerned about driveability now, so glad I asked for opinions!
      Quote Originally Posted by v8 stingray View Post
      Good question... I'm not really going to be driving this at the top-end, so low-down grunt & acceleration are the primary points. Shifting RPM, havent really thought of that to be honest - but like I said this isn't a track-day car, something more with the "wow" factor that I'll drive weekends and take to shows. I'm guessing max shifting RPM is going to be the 6,000-6,500 range. Heads will be stock, and I've purchased a new Tremec TR6060 transmission for the build.
      Then you definitely want something else. First of all, the LS3 heads stock, reach peak flow around .600" lift on the intake side. So any lift above that will only gain a handful of horsepower and push the rpm where it peaks, up higher. And it's already going to be pretty high (7000+rpm) with that duration. Plus even on ported LS3 heads, the flow is almost flat by .600" lift. So unless you plan on supercharging or stroking it, going that big will provide no benefit with a large loss of power in low and mid-range rpm.
      If you plan on shifting around 6500rpm, then Comp 146-458-11 would be a better choice. Peak hp will be the same as the cam your builder wants to use. If you're really planning on shifting closer to 6200rpm, the Comp 146-456-11 is a better fit. http://www.compcams.com/Technical/Ca.../pdf/page8.pdf Both will sound healthy, but have better driveability, and whoever has to tune this beast will appreciate it . Andrew's suggestion for the BTR cam is a good fit too.
      Which gear set did you pick for the Tremec? With those 4.56s, if you're doing distance then I'm assuming some highway driving (120km/hr), so you're going to want the .50 overdrive to keep things sane. Either the wide ratio set D, or close ratio set F (F probably better with your setup).
      Also, to add to the camshaft discussion, be mindful of piston to valve clearances above .600" on that engine.
      Mar 2013
      Napier, New Zealand
      Your a **** lol!!!
      Damien
      Napier, New Zealand
      Mar 2013
      Napier, New Zealand
      Hey
      Max shift probably 5k when tune finished. 11.5:1 compression, Heads are bone stock. TKO600 with close ratio overdrive, 3.5 diff gears with 26" tall tire.
      We have amazing roads here in NZ, no freeways anywhere close to where i live.
      Damien
      Napier, New Zealand
      Hey
      OP, what is the max rpm that you plan on shifting...
      https://www.webopedia.com/TERM/O/op_...al_poster.html
      Also, I have to go with Andrew on the whole 6.2L is not a 408. lol
      Mar 2013
      Napier, New Zealand
      Another ****!!!!! Go america!!!!!
      Damien
      Napier, New Zealand
      Jun 2010
      Deployed
      I would call Texas Speed. Dyno Proven, in house design cams. They even grind their own now.
      1970 Camaro/DSE build
      The Holley Dominator can drive dual DBW throttle bodies and would be an excellent system no matter which cam shaft you choose.
      Sep 2012
      That looks like a nice setup - you used that before Andrew?
