    Results 1 to 20 of 21
      Nov 2014
      LSA Lid on First Gen
      Does the LSA Lid fit in the first gen camaros with the hoses facing the back of the engine or do you need to use the ZL1 Lid?
      Mountain Springs, Texas
      The CTS-V lid with rear facing hoses is lower than the ZL1 lid.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Nov 2014
      Don
      Yes I was more concerned with the space behind the engine. Right now with the LS1 anyways, the back of the heads are real close (less than an inch) away from the firewall. With the LSA engine and lid and the coolant lines going out the back of the engine, do they need more room behind the engine than a regular NA engine?
      Quote Originally Posted by Nitrous View Post
      I think you will be ok. Hat does not extend as far as the heads.
      Don
      The space behind is fine,
      Nov 2014
      Perfect thank you both
      Jul 2018
      gnitro- Do you have a build thread for this? What Subframe? AC? I have a 69 and just bought a used LSA from Loyaltyisking (good guy). Looking to start installing soon and need ideas. Thanks!
      Nov 2011
      Wylie, Texas
      I used a couple of Dayco 90 degree bend heater hoses and the fit was perfect, there's still a small gap between the firewall and hoses.
      Jan 2007
      CT
      Quote Originally Posted by blitzer454 View Post
      Do you have the top of the supercharger heat exchanger fill t just open to atmosphere?
      ________________
      Nick S.
      Gold/Gray 1967 Camaro
      Nov 2011
      Wylie, Texas
      It's a closed system except for the fill reservoir. The plumbing is pretty much the same as the CTS-V. The hoses run under the fender to the pump which is also mounted under the fender next to the firewall.
      Jan 2007
      CT
      How about the top of the fill t is that plumbed into the system?
      I saw something similar done on the V8TV you tube channel. you can see in the video opening it looks like it open to air.
      https://www.youtube.com/watch?v=yNFas1Jpu9Q
      ________________
      Nick S.
      Nov 2011
      Wylie, Texas
      No, I just have a drain hose attached. That part is open to air. The reservoir needs to be placed such that it is as far up as you can get it. I normally have about an inch of fluid above the "T".
      Nov 2011
      Wylie, Texas
      Actually now that I think about it, the reservoir cap is a pressure cap so it really is a fully closed system.
      Jan 2007
      CT
      That's what I thought. Thanks!
      ________________
      Nick S.
      Nov 2014
      Quote Originally Posted by Shatafire View Post
      I bought an engine from him off here as well. Long story short, wasn't what I was told and I ended up buying an LSA from GM directly. I wasn't planning a build thread but may end up posting some pictures if I have some time.
      I hadnt planned on it. Im close.. wiring is all thats left, than start her up.. ohh waiting on the custom Dennys aluminum driveshaft Its a speedtech subframe and torque arm set up, Blake and those boys can hook you up.. Vintage air, TR6060 out of a Viper, Notice my custom made ZL1 emblems I cant say enough about Don Hutton and the paint and body he did on this car..
      The thing I like, I dont think I have seen to many LSA with remote coils.. need to clean the routing up.
      Not to high jack, but does it clear a flat hood, or require a cowl induction?
      Quote Originally Posted by 68Formula View Post
      definitely need a cowl
      Quote Originally Posted by qnitro View Post
      Why are you posting pics of Mike’s Camaro? LOL....
      Don
