      May 2011
      Tennessee
      Ridetech Muscle Bar
      I'm having a little problem with my Muscle Bar. It's on a 1970 Nova with the front and rear coil over system and Tru Turn from ridetech. I'm finding that the 3/8 flange bolts where the arm bolts to the bar are shearing off. I autocross about once a month and when the first ones broke I'm sure it's because they started to back out. That's a shocker when you're in a fast turn and the sway bar arm breaks off! I tried blue Loctite and am now using red Loctite to hold the bolts from backing out. These bolts are on my checklist for every event and I just found another broken one that wasn't backed out and looked tight until I checked it. When I did the bolt head fell off.
      The car weighs 3250 lbs without my 215 lbs in the seat so it's not that heavy. Is anyone else seeing this problem? Thanks.
      Indiana
      Quote Originally Posted by mbheinz View Post
      Very important to keep those bolts tight. If the bolts get even a little loose the jackhammer effect will shear the bolts. Loctite is certainly required. At this point the threaded holes may have become wallowed out to the point that proper torque is impossible. We can inspect and fix if you like. Speak with Darren at our shop. [email protected].
      Bret Voelkel
      Founder/ Former Owner
      How do you spell Impossible?
      May 2011
      Tennessee
      Quote Originally Posted by bret View Post
      Thanks Bret. That was what I suspected. The bolts still tighten up fairly well and I have been marking them with a paint stick so I can visually see if they move.
