      Aug 2018
      Orange County, CA
      Running too lean....
      I just Dyno'd my car to get a baseline. The shop noticed my car was running to lean and didn't want to take it over 5500 rpm (Red line is 7k). When I get a chance to tune it, hopefully they will fix the issue. In the meantime, I'd just like to have a better idea of what may be causing the issue. It has enough fuel pressure and I believe the O2 and MAF is okay. Any thoughts?
      Oct 2014
      DFW, Texas
      ...What is controlling it? What changes have been made to it? Was it well tuned before and no longer isn't? What was the AFR? What did the o2 correction look like, is that turned on? Does your o2 agree with the dyno's o2 reading? Got a datalog?
      There's a very large amount of information from this thread if you are seeking directional feedback. A video of it spinning the rollers doesn't tell me anything other than it runs..
      1972 Plymouth 'Cuda - Not LS-swapped, 5.7L Hemi [MS3 Gold Box], T56 Magnum 6-speed - 'Cuda Build Page
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
      Central CA USA
      On ours, the MAF had to be tuned/calibrated to the size of the inlet tube. It was underestimating air flow. I imagine this is a pretty common issue when aftermarket air inlet systems are used
      I hear turbos....it needs to be tuned! What ECU are you using?
      Aug 2018
      Orange County, CA
      Got it tuned
      Got my Camaro tuned, it runs like a champ now. thanks for the replies. They added more fuel and backed out the timing a bit.
