      Jun 2010
      Arroyo Grande, Ca
      fuel pump or fuel regulator
      EFI guys not sure if this is a issue but I'd thought I would ask. so my elco has a 383 with efi the first efi was Mass-flo, I got rid of that for a more user friendly tuning software holley efi hp series. well my question is the old EFI (mass-flo) then I shut down the engine the fuel pressure gauge would still hold pressure. but as soon as I went with holley it now bleeds down instantly. didn't know if that is the issue as I seem to have hesitation issues so was wondering if the pressure drop means my regulator could be going bad!
      More info is needed.
      What fuel pump? What regulator? Did the fuel system plumbing change when you switched to the HP?
      Newbury Park, CA
      Yep, plus where is the regulator located and plumbed.
      Oct 2014
      DFW, Texas
      When mine had problems holding pressure the hose inside the tank had shrunk and gotten loose...
      1972 Plymouth 'Cuda - Not LS-swapped, 5.7L Hemi [MS3 Gold Box], T56 Magnum 6-speed - 'Cuda Build Page
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
