    Results 1 to 12 of 12
    Thread: Gear indicator
      Mar 2013
      Country Flag: Belgium
      Gear indicator
      Hi All,
      Trying to figure out how to install a gear indicator gauge in my car.
      Only reason i want it is for getting a "race" look in the interior.
      Dont want it to tell me when to shift, just need it to indicate which gear i am currently in.
      Anyone has experience doing this on a manual transmission and no computer involved ?
      (Tremec TKO 600 behind a carburated engine (no efi)).
      Not really sure how to start fabricating this myself and were to find the gauge.
      Greets
      Oct 2014
      DFW, Texas
      I am not sure you'll find something without some sort of a computer. You'll need to interpret a button or (rpm vs vehicle speed calculation) to a numerical value and display it. You may get asked a bunch if you have an [expensive] sequential trans, since that's really the only application where a gear indicator is useful. I have a gear calculation within my ECU, but it's for datalogs only.
      If you're set on it, I would start by finding someone who has done it with an Arduino and go from there, you'll want a microprocessor of some sort...
      1972 Plymouth 'Cuda - Not LS-swapped, 5.7L Hemi [MS3 Gold Box], T56 Magnum 6-speed - 'Cuda Build Page
      1976 Dodge D100 - Warlock
      2016 Subaru WRX - E30 Tune
      Feb 2007
      Tinley Park, IL
      Mar 2013
      Thanks for the replies,
      seen the thing with the magnets before.
      I was thinking in a simplicity style ,
      Would it not be possible to just work with microcontacts on the gearbox itself,
      So each time the shifter moves in the position of a gear it would touch the contact and
      that way giving a signal to the gauge.
      Only thing is , how am i gonna make this gauge switch numbers....
      Most likely still need some sort of chip which can procces the contact and which numbers to display
      Just thinking out loud here, should be a possibility doing it with microcontacts on the gearbox.
      Cheers
      Oct 2014
      DFW, Texas
      Quote Originally Posted by 70CougarXr7 View Post
      Cheers
      Contacts can work, but they need to move with the transmission and are susceptible to adjustment much moreso than a hall effect.
      You will need a mircrocontroller of some sort..
      Mar 2013
      Thanks for the input,
      atleast got some guidance and know where to start.
      Will do some research on the controller etc and give it a go.
      Greets
      California
      Actually there's a company that makes a shift knob with a display in it to show you what gear you're currently in. I wanted it for a car I had a long time ago.
      They also make a display that mounts in the dash:
      http://www.indy-cator.de/engl/indy-cator-dash.php
      Looks like it's just a sensor that mounts to the shift lever, and you calibrate it to your transmission.
      Matt
      Mar 2013
      Quote Originally Posted by DarkoNova View Post
      Awesome find DarkoNova !
      And its in Germany, easy and cheap shipping for me!
      Will send them an email now.
      Thanks!
      Jonesboro, Arkansas
      Thanks!
      If you don't mind, let us know what you find out on this. I'm curious too.
      Carl Wilson
      Dec 2010
      Fredericksburg, VA.
      Quote Originally Posted by minendrews68 View Post
      Like Carl I am really interested in finding out how this works.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Mar 2013
      Will let you guys know as soon as i get it, company is slow in responding it seems...
      Nov 2007
      Windsor, Ontario
      I'm in on this also
