    Results 1 to 11 of 11
      Jun 2017
      Edgewater Co.
      Coil spring install tip
      Instead of compressing the spring and wrestling the thing in place and fighting with getting the spring compressor out, like this.
      IMG_20180508_142056328 by Joseph Martin, on Flickr
      Don't use the upper half of the compressor, instead drop the bolt through the upper shock mount hole and engage with the lower half of the compressor (note this works for through sock applications, where the shock rides inside the spring.)
      IMG_20180508_142443502 by Joseph Martin, on Flickr
      think of the spry can as the top of the frame where the shock comes through... Note you need to make sure the spring is clocked correctly before compressing the spring or you'll have to run it back down turn the spring and do it again, also it may take a little prying to get the spring in the pocket, but I find this way much easier and safer...
      Joe
      Feb 2013
      South Carolina
      Wish you had posted this before my coil over kit. Great idea.
      Jun 2017
      Edgewater Co.
      That's probably where this shines best, turns spring removal into a simple/safe task... Sorry I didn't post sooner, the idea hit me when I was doing the springs and tall ball joints in Frankenstine last weekend, the job went soo smooth, I forgot to take pics...
      Joe
      Nov 2014
      SoCal
      Is this method used for both removal and installation? What do you use at the top? Not quite seeing how this works.
      Dec 2011
      Oregon coast
      Quote Originally Posted by Closf71 View Post
      Depend son on your application. This method works best for cars like GM A, F, and X bodies where the shock mounts inside of the spring. You would just put the threaded rod through the hole for the top of the shock and put a bolt on to hold it in place, the spring bucket hold the spring in place while you tighten it from the bottom. You could do it for a mustang too but you'd probably need a big washer or make your own plate since the hole for the shock is larger.
      Nov 2014
      SoCal
      Thank you for responding. Based on the picture above where the spray can represents the frame of the vehicle (2nd gen F-body), wouldn't i tighten the bolt from the top?
      Nov 2014
      SoCal
      BTW, nice 69 GTO. Awesome workmanship.
      Dec 2011
      Oregon coast
      Yes that’s how you would do it. You’d just tighten the bolt from the top the same way you’d bolt
      up the shock and when everything is installed you’d just unscrew the spring clamp and drop it out the hole in the lower control arm.
      Nov 2014
      SoCal
      Thank you for clarifying
      Nov 2014
      SoCal
      Out of curiosity, how much space do most of you have between the lower control arm rubber bumper and the frame on a 2nd gen F-body? I have about an inch. I feel the springs are too short or too soft for my vehicle.
      Jul 2019
      Ohio
      We used to just pop them into the spring pocket on the lower A Frame with a block under it and then jack it up the control arm and attach the ball joint after trapping it with the shock absorber. Of course we didn't care about scratching up the control arm back then either.
