      Houston, TX
      Help with bleeding new clutch MC.
      Hi guys,
      I'm in the middle of swapping in a TR6060 to my Firebird, and I'm using the McLeod hydraulic conversion kit, with stock GM slave and Tick remote bleeder. The fluid is Wilwood brake fluid. The clutch is the Centerforce DYAD setup.
      Below is the link to the kit I'm using.
      https://www.jegs.com/i/McLeod/673/1434002/10002/-1
      For the life of me I couldn't get a firm clutch pedal. I removed the line from the MC, put the end into the reservoir, pumped the pedal and got all the air bubbles out, reconnect the line to the slave cylinder, bled the system until clear fluid (no bubbles came out), but the pedal is still soft. Pumped the pedal hard 10 times, and it firmed up the last 1/3 of the stroke. Cracked open the bleeder and the pedal sank to the floor. Did that multiple times, with almost 2 bottles thru the system. Now the clutch pedal sank to the floor, regardless how many times I pumped it. Checked the reservoir and filled it too, as the fluid level went down a bit.
      I checked all connections, and they're dry with no visible leaks. I'm getting a borescope to peak into the bell housing to see if I'm getting leaks there.
      I'm running out of ideas. Called McLeod and they gave out some suggestions, which I tried without success.
      Any helps/ideas from the forum would be greatly appreciated.
      Thanks.
      Tu Ho
      Firebird V2-LS swap
      Feb 2011
      dallas, tx
      https://m.youtube.com/watch?v=J5CXYizgC8k
      Delt with the same issue. 5 min this way and it’s fixed. The hose is sucking the feed hose of the reservoir.
      Houston, TX
      Quote Originally Posted by icemanrd19 View Post
      I may have to try that. I have the same mighty vac vacuum set up.
      Tu Ho
      Firebird V2-LS swap
      Did the Tick remote bleeder line use a copper crush washer where it attached to the slave? Any sign of the slave leaking at that location?
      Houston, TX
      Yes. The Tick has a copper crush washer installed at the slave. I ordered a borescope to peek thru the hole, to see if there are any leaks.
      I tried vacuum thru the reservoir and a punch of bubbles came out. But pedal still soft.
      I also got a -4 an plug and plugged the end of the line going from the MC to the slave, and pumped the pedal. It should be rock solid after a few pumps, but the pedal went straight to the floor. I think I maybe have over traveled the stoke, and damaged the mc
      Tu Ho
      Firebird V2-LS swap
      Dec 2008
      Detroit
      Quote Originally Posted by rickpaw View Post
      Same way I had to bleed mine. It works
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Feb 2013
      South Carolina
      Do you have a power bleed unit?
      I had he same issue years ago and their kit solved it in a few minutes.
      Houston, TX
      Quote Originally Posted by csouth View Post
      Quote Originally Posted by JustJohn View Post
      I think I may have damaged the MC by overstroked it. I removed the line to the slave, and plugged it with an AN plug, similar to plugging the ports on the brake MC. Pumped the pedal a bunch of time, and still have soft pedal.
      Tu Ho
      Firebird V2-LS swap
