    Results 41 to 60 of 81
    1. #41
      Oct 2012
      Kennewick, WA
      I bought that same wiring kit, very nice for the price.
    2. #42
      Mar 2013
      Country Flag: Belgium
      Quote Originally Posted by RMMiller View Post
      Sure is a nice kit!
      Only its a basic and for a cougar its a bit tricky to make it all work with the sequential tail lights.
      And still figure out what to do with that pink cable...how to make it work with the MSD box, getting there though...
    3. #43
      Mar 2013
      Spacing issues with the electrical fan.
      Any idea's how to solve this?
      Its a 3row radiator and as you can see i only have a around 5mm of extra space i can put it to the front, so that is not enough to clear the fan from the pulley.
      In the picture the fan is next to the pulley but in reality it should be in front of it...
      Cutting and welding is not an option to make it fit because it means i have to cut through the support frame of the car.
      Only option i would see directly is putting the fan on the other side of the radiator and then reverse the rotation of the fan?
      But i do not know if that is a good idea?....
      This is how the fan/fan bracket sits when looking at the other pictures...should be centered
      spacing between radiator and car frame
      Spacing between radiator and car chassis
      Like to hear your thoughts,
      Greets!
    4. #44
      Mar 2013
      So little update, first startup of the new 408.
      Well probably the 5th startup since i had do some adjusting...but lets call it first startup ;)
    5. #45
      Sounds good! Flowmasters?
    6. #46
      Mar 2013
      Hi Andrew, thanks!
      No these are Gibson MWA ( always looking for something different).
      Was not sure what to expect from sound but i am liking it!
      (3inch pipes probably make that deep sound also).
    7. #47
      Mar 2013
      Some small updates, electrical system is almost completed, just need to fix the wiper washer motor en the power windows.
      Once that is done, going to start on the interior, still waiting for parts...
      Just a quick peak of the new wheels which i just fitted, bought them really cheap on a sale.
      Wheels are from jegs, 17x8 size, tires are bridgestones 215/40/17 front, 225/45/17 rear
      Should have gone with a 17X9 in the back to make it fit perfectly, but was not sure...will probably buy that size later on, still like the look!
      Hard to get a picture from the side with all the tools behind me etc..
      Did some fabricating on the instrument panel, gauges are from new vintage usa, really pleased by them.
      Look modern but still simple like it was back then...
      Panel has some tape around it because its a first try, will finish the real one with a chrome molding around the plate
      Offcourse you will only see the panel where the screws are, rest is going to be surrounded by the dashboard.
      Indicator are not from new vintage
      Also installed a modern radio below the switches, not that clear in this picture.
      But just to give you an idea, gauges are red light, switches are red lights and the radio to, like those red lights, pretty pimp!
    8. #48
      I'm pretty sure you could have gone with wider tires. I wish there was more, concrete, fitment guidelines for Cougars. I have 225/55-16s on my Cougar now and I can for sure go wider in the back and maybe in the front as well.
    9. #49
      Mar 2013
      I hear that, not at all simple to get information on a cougar when it comes to putting non standard stuff on it....just not a big protouring fanbase on this car it seems...
      As said for the wheels/tires, will go bigger next year most likely....still liking the look.
      Gonna focus on getting this thing out for a test drive in a few weeks, just need to measure the lenght for the driveshaft and order it, delivery will take a few weeks...
    10. #50
    11. #51
      Oct 2018
      Phoenix, AZ
      Wow you've been making awesome progress! Congrats on having it running. Not too much longer and you'll be driving around.
      What all was done to the motor? I know it's a stroker with heads and a decent sounding cam.
    12. #52
      Oct 2011
      Maryland
      Any update?
    13. #53
      Mar 2013
      [img]https://i.imgur.com/rpAAl6F.jpg[/img]
      Long time overdue...jobs abroad keep this thing from getting finished.
      Some small updates though.
      Interior is almost finished from the upholstery shop.
      Door panels will be finished somewhere next month.
      Dashboard and rear seats are done.
      Will take a better picture later from the dashboard
      Just need to make a bracket for the front seats now and the interior can be installed.
      Was planning on making a custom center console but just found the original back and
      will use this one, just get in upholstered again with some custom touch to it.
    14. #54
      Mar 2013
      Finally got the turn signals working as it should, was a pain in the ass!!
      All led light bulbs.
      Like the indicators on the dash!
      Electrical is almost finished, just need to connect the horn and the temperature sensor.
    15. #55
      Mar 2013
      [img]https://i.imgur.com/E5D35WO.jpg[/img]
      Front panels are finished, back panels will be done next month.
      This was the sketch we came up with:
      This was during the construction
      Bought this flat panels and frames "new" from west coast classic cougar and the guy from upholstery is using his magic to give it some form
      (Sold the old panels for 500dollars, some stuff for a cougar is rare and expensive!)
      And this is the result, guy has a crappy camera so you don't really see the details at the moment...just blurry black and brown...but you get an idea this way
      Will get them next week and get a decent picture.
      Need to paint the door handle black in my opinion now...
    16. #56
      Mar 2013
      Most things are working but struggling with the engine, running rough at idle...
      and currently not enough buildup of pressure on the throwout bearing from the transmission.
      When bleeding no air comes out but need to get the pedal completely to the end to get it in first and that is a struggle...
      Going in reverse is not working, just cracking sounds when pedal is pressed down completely.
      Not sure what is wrong there but will start a different topic on that.
    17. #57
      Aug 2006
      Star,Idaho
      That is looking really good. What size speakers are you using in the front doors?
      70 Cougar
      Aces Kill shot efi
      T70 Turbocharged 302 430hp 488tq
      Tremec 3550
      13" Cobra brakes
      Unisteer Manual rack
    18. #58
      Mar 2013
      Quote Originally Posted by 705.0Merc View Post
      Currently nothing since the ones i had will not fit anymore...
      Need to find something small but powerfull that will fit in that speaker hole..
      Thanks for the compliment!
    19. #59
      Feb 2007
      I moved the radiator forward by making the opening bigger.. some people just lean it forward.. i ended building a custom radiator support.Name:  46492186_10155970660858424_8949694624809615360_o.jpg
Size:  275.4 KBName:  20181130_170054.jpg
    20. #60
      Feb 2019
      Kankakee IL
      Quote Originally Posted by GT500KR_Vert View Post
      I'm thinking of doing the same thing. Did you fab the entire fender support panel or just blend in a shock tower eliminator panel?
      Tracey
