    Results 1 to 17 of 17
      Jacksonville, FL
      Ridetech new R Joints?
      I was wondering if anyone has put their new joints into their 4 link suspension yet? Looking into them to get rid of the noisy heim ends I currently have. Any feedback would be appreciated.
      https://www.ridetech.com/products/r-joint/
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Arizona
      There's not much of a choice other than Johnny joints. ridetech says they are the only way to go. Wish I had known that before I ordered mine.... They have a retrofit kit Part # 11009516, comes with R-joints and a left hand 3/4-16 tap . They want somewhere around $650 for the kit. I think I will wear out my poly joints before I indulge.
      Jul 2015
      Guess I don't see what makes them worth twice as much as these:
      https://www.spohn.net/shop/Del-Sphere-Pivot-Joints/
      Arizona
      Those don't have a neat little R on them........
      Lawrenceburg, TN
      Quote Originally Posted by krom View Post
      the spohn ones are chromoly housing unit with a chrome plated steelball, 28 degrees of available rotation, and you have to adjust them as they wear and select your own friction level as you manual adjust them and they need to be cleaned and greased......
      the ridetech ones are investment cast stainless with rolled threads and polished stainless ball and special Delrin compound needs NO lubrication and has a spring loaded self adjuster so its always tight, 30 degrees of total lateral rotation, self cleaning design
      that's what I found different on each website
      Jul 2017
      I just installed my new ridetech 4-link with the r-joints on my 68 and it is very quiet compared to my 96 camaro that had hiem joints. As for performance, I do not have an answer yet.
      Dec 2010
      Fredericksburg, VA.
      Please let us know how you like them! I will be curious to see how they wear. I don't like the noise I get with my G-Link heim joints so I will have to keep an eye on these for possible replacements.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Jan 2003
      Arizona
      It may be a while before there is any feedback on R-Joint wear. As part of our durability testing process, one of our test vehicles is a 5200lb Suburban. It was daily driven for 15,000 miles with a full family and gear in all weather. Likewise, we tested R-Joints in Smitty's Corvette throughout his championship-winning 2017 race season. We run them in both 48 Hour Camaros as well. We have not yet been able to measure appreciable wear in a street or autocross/track day environment. We will keep trying -- Promise....
      /Steve
      ________________
      Steve Chryssos
      Oct 2009
      old thread but i have a question. if you got the double adjustable r joints on the bolt in 4 link, what keeps the rear housing from having lateral movement?. i have the first generation 4 link in my camaro with single adjustable lower bars and full heim joint upper bars. and i feel the lower bars keep the rear centered because of the solid mount that bolts to the torque box
      1969 frost green camaro
      LS3
      Speedtech pro touring front subframe
      ridetech rear 4-link
      moser 12 bolt eaton tru trac 3.73
      Beach Park IL
      It is the triangulation of the upper bars that keeps the axle centered, not the bushing. If it could be done with bushings, other suspension designs wouldn't need a panhard bar or watts link.
      Donny
      Feb 2013
      100% correct, thanks Donny
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Jacksonville, FL
      I wanted to give some feedback after putting some miles on them. The R-joints are night and day difference compared to my old style heim joints that cane with my original kit (circa 2008). No more squeaks and pops from articulation and it seems “smoother”.
      Donny is 100% correct. Centering the rear is very easy With the upper bars. Besides setting the pinion angle, you are able to maneuver the rear but lengthening/shortening one side and doing the opposite with the other bar. Just do the same amount of turns/flats adjustment on each side.
      Chris
      Chit-ca-go
      Interested to hear any other opinions on the updated design.
      1971 Firebird
      2017 Slipstream SS
      Jan 2021
      Tennessee
      Quote Originally Posted by cpd004 View Post
      Interested to hear any other opinions on the update design.
      My original upper bar heim joints did the "popping" noise once they warmed up. I recently replaced them with the "R" joints. Been on the road for about a week with them and so far so good. Nice and quiet and hoping they stay that way.
      Jul 2018
      I did the kit with the Double "R" joints, one on every end. I've only gone around the block a couple times but as soon as I get rims i'll be putting some miles on them and see how they are.
      Resized_20201202_203928 by F G, on Flickr
      I am about to install a complete ridetech A-body system with the R-joints, and I am pretty excited about it!
      Feb 2007
      Tinley Park, IL
      Quote Originally Posted by Josh@ridetech View Post
      Josh, i already have UMI rear control arms with heim joints. Can I purchase R-Joints to replace just the heims, instead of getting all new arms? I'm not sure what the thread size is off the top of my head.
      Nick ~
      1969 Cutlass
