      Jul 2007
      Tracy, CA.
      PSI alternator connection ?
      I ordered my PSI harness with a 2 pin connector, but have ended up with a 4 pin alternator. I spliced in a 4 pin connector that I got from PSI, but it did not come with instructions and now have a power wire on the 4 pin that needs to be hooked up. I am not a wiring guru in any way and learn as I go, that being said...is this power lead supposed to be switched or constant? if constant, can I just connect it to the power lug on the alternator? (Powermaster alternator, if that matters?).
      Steve Martin
      67 Camaro RS
      66 Chevelle
      Nov 2011
      Wylie, Texas
      The (I)gnition terminal of the alternator should be connected to a switched 12v source. The (S)ense terminal should be connected to the main power distribution point which for a Camaro would be the fuse block or the horn relay.
