    Results 1 to 16 of 16
      Jul 2004
      Braselton, Ga.
      Valve stem hitting!
      I just noticed that the valve stem is hitting my brakes. What am I going to do? I am running INTRO's and the valve stem is hidden on the inside of the wheel. I thought that was pretty neat but it is causing a problem now.
      Thanks , Brent
      Jul 2002
      Muskegon, MI
      How much of it is it hitting? Pics?
      Nov 2001
      Sacramento Ca
      are they flush mount? they should be.
      http://performanceunlimited.com/cobr...alvestems.html
      there are lots of them on the market for this purpose. do a google search for flush mount valve stems. or hit up a big time local tire shop. (like les schwab)
      Tony Langlois
      1966 Corvair Monza
      Nov 2001
      Sacramento Ca
      Tony Langlois
      1966 Corvair Monza
      Jul 2004
      Braselton, Ga.
      Valve stems
      Thanks, that will take care of it!
      Brent
      Jun 2002
      Benicia, CA
      Is filling tires difficult with this setup?
      My valve stems may be in the way as well, at least on the front wheels. They are behind the spokes by about 2", so filling with air may be too difficult. Does anybody here have any experience with these stems???
      Jeff
      1971 RS Camaro: PAINKILLER
      Nov 2001
      Sacramento Ca
      basicly you'd have to remove the wheel to air it up. the "stems" come with a long tube that threads into the valve so you can air it up conventionally.
      looks like this
      Tony Langlois
      1966 Corvair Monza
      Jan 2000
      Thousand Oaks California
      I had the same problem with my Intro's. I plan to plug the hole and put a new one on the front side. While it would look nicer the way it is I don't want to get burned by the rotor while reaching around to change the air pressure at a track day. Just something to think about.
      Larry Callahan
      Jun 2002
      Benicia, CA
      Resurrecting this one...
      Any recent feedback on flush mount stems? Any other providers besides the one's already listed? Will need them soon...
      Jeff
      Indiana
      I ran into this problem with my Intros and Baer GT brake setup. Fortunately, by leaving the cap off the valve stem, there was enough room for clearance.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Indiana
      I forgot to mention, I looked into the flush mount valve stem and was told by a few different tire people that the flush mounts have a tendancy to leak air at a slow rate. I never tried them so I can't speak from experience, but it may be something to consider.
      Herb
      Jun 2002
      Benicia, CA
      Quote Originally Posted by Yelcamino
      Herb
      Just my luck, my only option and they have a tendency to leak...
      Jeff
      May 2000
      I've used flush mount, and the type that is the heigth of a dust cap, neither leaked.
      Most places carry the dust cap size valve stem. If those will clear.
      Feb 2006
      Elk Ridge, Utah
      Herb
      I think the only way they would leak is iff they were installed wrong.
      the oring goes on the outside and the rubber seal ring on the inside like any other threaded valve stem.
      My fronts were installed wrong and they leak the rears are correct and they do not leak after almost a year.
      I could be wrong.
      69 Camaro
      W/D sub, Wilwood 13" brakes Bozeforged wheels 18X10 & 18X12,
      Lateral dynamics 3 link ( custom setup ) Dana 60
      lsX Twin Turbo, soon to come
      Viper T56 in place (Yay)
      Bought a running driving car so I can enjoy it before Im dead
      LD 3 Link Installed into ^^^^^ (Yay)
      Indiana
      Like I said, I never tried them before, but I've heard a few folks recommended that I don't use them.
      I guess it's like anything else... if it's not installed correctly it's not going to work as intended.
      Herb
      Jacksonville, NC
      "The low profile offers increased wheel speed for racing."
      hmm, i'm sure it does.
