    Results 1 to 20 of 25
      TKO 600 shifters
      I've got the factory Tremec shifter, which looks fine (at least it's not made from stamped steel like the factory T56 shifter).
      Anybody use an aftermarket shifter with their TKO-600? Thoughts, comments?
      jp
      ​John Parsons
      NJ
      looking to but the mcleod trick stick, I think thats the name comes highly recommended
      Encinitas, CA
      The McLeod Slik Stix shifter works very well. You can learn more about it here:
      http://www.classicchevy5speed.com/TK..._positions.htm.
      Jeff Mortenson
      Northwest
      Not sure if it would fit your II but pro 5.0 makes a nice shifter as well. It seems to have built in stop bolts etc and looks pretty beefy. price was 199.00 from PRO5.0. I don't think that it would be console friendly but couldn't say for sure. Standard shifter is a hurst piece if I am not mistaken and works well. SS
      My Chevy II console (and tranny tunnel) have long been in Nova heaven. That's not a consideration. I was unaware that the Pro 5.0 would work on a TKO-600. Is there any certain model or will all of 'em work?
      Jeff, will the McLeod bolt up to shift levers that bolt to the stock shifter?
      jp
      ​John Parsons
      Jan 2000
      Thousand Oaks California
      All this talk makes me think twice about my Richmond 6 speed. While it's probably a nice tranny it's sure not an easy one to shift. I'd love for the wife to drive the car but the hard shifting bothers me. Maybe after some miles are on it.
      "Not wanting to hijack this" Please return to your regularly scheduled thread. lol
      Larry Callahan
      Founder / Administrator — Pro-Touring.com • G-Machines.com • HostMyJunk.com
      SEMA Hot Rod Industry Alliance Hall of Fame — Class of 2026
      Advertise on Pro-Touring.com • Shop Pro-Touring.com Merch
      Encinitas, CA
      The McLeod shifter stub has a bolt pattern that will accept shifter sticks with a 7/8" center to center bolt spacing and 3/8" ID hole size.
      If your stock shift stick has this spacing and ID hole size you are good to go.
      Keep in mind that the physical location where your stock shift stick bolts to the stock shifter mechanism is in a different physical location than the stick mounting point for the McLeod shifter (or any other shifter you may use on the TKO for that matter). This means that if your stock shifter will bolt to the McLeod stub (bolt pattern matches up) the physical location of the shift knob/handle will be in a different location when installed on the TKO as compared to where your stock shifter positions the stock ball.
      I hope this makes some sense.
      Jeff Mortenson
      Jeff,
      I get the 7/8 x 3/8 bit. I'm good there.
      I'm not following the other part, though. I have a brand new TKO-600 with its original shifter. Where does the McLeod shifter end up with respect to the original TKO-600 shifter?
      jp
      ​John Parsons
      Encinitas, CA
      The McLeod shifter stub holes are slightly lower (but not much) than the stock Tremec shifter holes. I would imagine that the original Muncie shifter mounting holes for the shift stick are lower, further to the left, and possibly at an angle. All of these variables from one shifter to the next will put your shift knob in a slightly different position.
      In other words if you install the exact same shift stick onto three different shifter mechanisms (McLeod, Tremec, original Muncie), your shift knob will be in a different place with each shifter because each shifter has it's mounting holes in a slightly different place.
      The diference between the Mcleod shifter and the Tremec shifter would be minimal but the difference between these two shifters and the stock Muncie shifter would be greater.
      If you have further questions, feel free to call me.
      Jeff Mortenson
      Northwest
      Not trying to take away any business from Classic Chevy5speed because Jeff is really good to deal with. The Pro 5.0 has a specific TKO 600 shifter. http://pro50shifters.meridian1.net/I...arge/P5000.jpg
      SS
      Delaware, OH
      I replaced my stock Tremec shifter with a Pro 5.0 unit. Although it's a high quality billet piece, I can't feel any difference in shifting performance. It certainly didn't shorten the throw a lick. I'm not knocking it (ok, maybe a little), but for me, it wasn't any better than stock.
      Dan
      Dan,
      Thanks for that. It seems the McLeod unit may actually improve the shift feel and/or shorten the throw, so I might pursue that unit.
      jp
      ps. I dig your front air dam. Did you make that?
      ​John Parsons
      Reading, PA
      Quote Originally Posted by Larry Callahan
      You will need to rework that Richmond to make her shift easier for your wife! Richmond designs their transmissions around the Super T10 strut key and sliders. These items need to be replaced with the early style T10 parts from the '57-'63 T10. Big difference in the shifting.
      Sorry about the Hi-jack reply!
      Regards, Jody
      Jody Haag
      [email protected]
      Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
      610-413-8015
      Jody's Transmissions on Facebook
      Jan 2000
      Quote Originally Posted by JodysTransmissions
      Regards, Jody
      Thanks Jody!
      Larry Callahan
      Encinitas, CA
      The possible reason you may not be able to tell the difference between the Hurst Pro 5.0 and the stcok Tremec shifter is that they are both made by Hurst - the design is bascially the same.
      The McLeod shifter uses a series of belleville style spring washers instaed of coil s prings used by Hurst - this is why the McLeod shifter feels different.
      Jeff Mortenson
      NJ
      anybody have part numbers for the slik stik for a 1970 camaro and a 67 camaro for the tko 600.
      Encinitas, CA
      We catalog them by the car year and model:
      1967 Camaro TKO Slik Stix shifter
      1970-81 Camaro TKO Slik Stix shifter
      If you order direct through McLeod, just let them know th eyear of car you have and they will take care of you. You will need to talk to Red about these shifters.
      Jeff Mortenson
      Just ran across more options:
      http://www.mgwltd.com/mustang_shifter.shtml
      http://pro50shifters.meridian1.net/default.asp?S=503&A=E&PKV=P5000|0
      Dec 2002
      Lost Wages, Nevada
      The Long Shifter (Leanard Long built the units for Richmond) needs a little tuning as well. It requires a little gate 'edge blending' as well as some simple (internal trans) slider tuning and streching of the energizer springs to improve the engagement the dogs (strut keys).
      Jul 2001
      Detroit, Michigan
      Jeff Trush has one of the sickest sticks in his '69 Convertible. Kyle at DS&E made it for him. I'm going to get the same one once I'm ready. Strange that Kyle has never advertised it for sale.
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
