      Nov 2011
      Country Flag: Norway
      LS1 Power steering hose
      I have a LS1 from a C5 Corvette in my -69 camaro.
      What kind of fittings do i need on the servopump? Have Unisteer rack and pinion
      What style fittings are on the Unisteer rack?
      Nov 2011
      They use 14mm 16mm and 18mm Banjofittings.
      I'm don't remember wath I have. I'm at work wont be home in a couple of weeks so I can't check.
      Mountain Springs, Texas
      You are going to need one of these on the pressure side to clear the pulley.
      http://www.jegs.com/i/Earl's/361/961...SABEgJbVvD_BwE
      Return side is just a hose barb on the reservoir.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Nov 2011
      I would also inquire what sort of pressure and volume is needed for the Unisteer rack. Then contact TurnOne for the necessary parts. For the actual hoses, I suspect that a local industrial hydraulic hose maker can set you up. In the industrial world AN fittings are called JIC.
