    Results 1 to 19 of 19
      May 2008
      Chicago
      4L65E behind an LSA
      What is the opinion on bolting a 4L65E behind a stock LSA. The car will not be raced and the motor will be left stock, at least for now.
      Mountain Springs, Texas
      I think there is a good reason the GMPP Connect and Cruise LSA package has a 4L80E instead of the 4L65E/4L70E that comes with most of their LS packages. The LS7 comes with a 4L80E too...
      I would not do it. Do it once and do it right.
      Drive an LSA powered car and you will understand how hard it is to take it easy.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      May 2008
      Chicago
      I have a 6L90E that is currently on the motor. With that being said I did not wan to open up the tunnel on a car that has a finished bottom. I guess I will look into a 80 and see where that sends me.
      Wayne aka Motown454 on this site has an LSA and 4L80E in a 69 Camaro. He has a build thread.
      Don
      GMPP has a 4L75e that they rate at 650lb/ft...
      http://www.chevrolet.com/performance...ermatic-4l75-e
      Mesa, Az
      We have a 6L90E in our latest build. Will never do that again. What a tuning nightmare unless it's 100% stock. Found out that the MAF even controls the trans shifting!!
      -Paul
      1969 Camaro "Reckn8"- LS7/C4 Front and Rear
      1965 Oldsmobile F/85 LS6 W/Maggie, 6-speed,Ride Tech, Baer brakes
      1978 Blazer 2 wheel drive with LS power
      1965 VW bug. All original
      1968 GMC short box
      1964 Buick Riviera
      Quote Originally Posted by Reckn8 View Post
      This is why I recommended Speartech for the 6L90E with an LSA. They are one of the few capable of properly tuning a 6L90E.
      Don
      Jul 2011
      Istanbul / Turkey
      Country Flag: Turkey
      I have had 3 rebuilds with 4L60E with stronger internals from Sonnax but i still peeled it like an onion in the end. Now i have junkyard takeout 4L80E and never had issues for the last 2 years. Only thing not stock is my 3500 TC. On the second gen firebird, it took a few persuasive hits to the tunnel to accept the case but worth it a million times.
      Spend once i say.
      Being handsome is only skin deep. But Badass goes to the bone.
      Mert Celet
      Looks like GMPP now offers the LSA with 4L75E or 4L85E.
      Don
      Apr 2010
      Cove, Texas
      I run a built 4L60E behind my LSA. No problems in over 3K miles. Like anything else, you need to put the right parts in it and it will survive......
      T,
      Feb 2011
      4L75E is the answer, and only around $3k if you shop around. Smaller than the 80, tougher than the 60/65/70, and brand new.
      70 GTO - Alum 5.3/4L80e, 7875
      17 GT350
      Sep 2017
      Detroit, MI
      I've had nothing but rotten luck with 4L60's and their variants, even behind stock power plants. Would not recommend, 1 out of 10
      80e's are almost indestructible. The 6 speeds are a nightmare to calibrate.
      May 2008
      Chicago
      So my next question is can you use the 65E trans controller on an 80
      Quote Originally Posted by kochevy67 View Post
      Pretty sure you cannot. You could buy the GMPP controller and harness for the LSA and 4L80E, assuming it is still available. If not you could use the GMPP LSA 4L85E trans, harness and controller.
      Answer subject to fact checking...
      Don
      Apr 2010
      Cove, Texas
      What controller, perhaps a T42?
      T,
      Different controllers listed here:
      http://www.chevrolet.com/performance...rtrain-systems
      Don
      May 2008
      Chicago
      Don
      Thank you very much for posting this.
      Dec 2015
      I've got a built 4L70 behind a Forged LS2, 370ci, Cam, TEA heads, Magnuson TVS supercharger, headers. Best guess is the engine makes about 650 at the tire.
      This is in an All Wheel Drive Trailblazer SS with a Yank stall converter. It is very hard on trans, and it is raced regularly, this thing has probably 200 1/4 mile passes on it. The builder I use requires shipping it halfway across the country to him, but he is worth it.
      Jun 2011
      Brooklyn, NY
      You can use a stock e38 pcm with a t42 to control a 4l80e. Just have to use a truck tune as a baseline. T42 can control either 4l60e or a 4l80e. If you’re ditching the dbw you can use a 0411 pcm to control a 4l80e as well.
