    Thread: Pulley Aligment
      Oct 2011
      Pulley Aligment
      Hey guys installed an L99 power steering pump on my LSA which was pulled from a 15' ZL1 I figured since they are both an LS3 everything would long up as far as pulleys. Anyway here is a pic of the power steering pump in relation to the alternator. I think it's about 1/8" off. What you guys think is this ok, or will the belt come off eventually?
      Jun 2010
      Deployed
      I don't like it, but I'm a perfectionist. I don't think the belt will fly off, but something ain't right. Is the alternator original to the engine?
      1970 Camaro/DSE build
      Oct 2011
      The alternator is original to the engine. Only the power steering pump is not original. The power steering pump pulley is pressed on maybe I can push it in a little? What do you think?
      Apr 2010
      Cove, Texas
      See if the pulley can go on further. It will probably come off.....if not it will certainly feather the edge of the belt. You can check it with a straight edge to see if you seated it further. It takes a special tool to push it on further....
      T,
      I bet the PS pulley is not on all the way. No way OEM is off by 1/8".
