    Results 1 to 10 of 10
      Jul 2016
      GMPP LS3 crate engine starter
      Which starter did you LS3 guys use ?? I will be using a TKO 600 5 speed trans. The GMPP instruction sheet states to use the 10465385 starter ? I wasn't sure if this starter was for automatics only. Thx.
      Feb 2011
      dallas, tx
      I used a bosh sr8581n . Ordered from amazon
      Jul 2016
      Thank you. How about the bolts ??
      Jun 2010
      Deployed
      I use a pure energy stater. Got it off of Rock Auto
      1970 Camaro/DSE build
      Jul 2016
      What part# ? Thx
      Jun 2010
      Deployed
      Quote Originally Posted by DT69Cam View Post
      What part# ? Thx
      http://www.rockauto.com/en/parts/pur...ter+motor,4152
      I used the AC Delco 5th gen Camaro starter. There is also a really cool heat shield that can be bolted right to it and I like the fact that it has a connector for the solenoid.
      http://www.rockauto.com/en/moreinfo....444223&jsn=525
      https://www.amazon.com/ACDelco-12617.../dp/B0031IBRZA
      The Amazon link has links for the bolts and the pig tail. If you look through my Cougar build there, I have the heat shield and the screws for it in there somewhere.
      Jul 2016
      Thank you Andrew.
      Apr 2012
      Woodstock, IL
      We use the Tuff Stuff starter. Summit usually stocks them.
      SchwartzPerformance
      Jul 2016
      Thanks guys. Parts ordered.
