      Oct 2006
      Norway
      Adjustable Proportion valve design.
      Are the typical adjustable valves like Wilwood etc. Just a needle valve ? Reason for asking is that I have a 1/4" stainless 6000psi Hoke needle valve in my shop. If this can be used I don't see any reason getting another one.
      Quote Originally Posted by Olav View Post
      No.
      Bob.
      Oct 2006
      Norway
      Thanks, have seen people using this style needle valves. : https://www.new-line.com/nldocs/catpages/587.pdf
      Oct 2006
      Norway
      May 2010
      kitchener,Ontario,Canada
      Or just buy the right part to begin with ...Yours and others lives depend on it !
      Ryan Austin
      On Instagram ryanaustinss70
      Here are a couple of articles that explain brake front to rear bias and why proportioning valves can be required:
      http://www.stoptech.com/technical-su...tioning-valves
      http://www.stoptech.com/technical-su...alance-matters
      Bob.
      Oct 2006
      Norway
      I will not or don't have any intetnions of doing a short cut. I found the speedway motors valve http://www.speedwaymotors.com/Speedw...alve,1979.html and it made me thinking. I also saw a valve of same design as the one on link i posted. (The small one on bottom of page) fitted to a camaro a few weekends ago.
      May 2010
      phew ...I've heard too many stories of short cuts and it hasn't had good results , best of luck with whatever you do hope everything works out
      Ryan Austin
