      Feb 2007
      Montgomery, TX
      Gem rust coating
      Hey,
      Have another project in the works and mostly lurk, but thought I'd tap the knowledge base here.
      After media blast, the fab shop uses a product called Gem Rust Killer to prevent flash rust as it is very humid here. They say after body work is complete, it can be epoxy primed and provides a good surface to do so.
      Has anyone done this with Gem or similar iron phosphate product?
      I ask because a different dustless blaster said he epoxy primes the car after blasting.
      Brian
      Mountain Springs, Texas
      Bad idea imho. If that product is not properly neutralized it will lead to paint failure down the road. Epoxy primer is a better way to go.
      Dustless blasting sucks too. That stuff gets everywhere and is tough to remove. And it does not reduce warping. That is a myth...
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Feb 2007
      Montgomery, TX
      Thanks Don,
      That's what I've been thinking as well, but the fab shop swears by it. They'll have the car blasted, but gem coat it. I can't find a painter that does this.
      What would you suggest for blasting/stripping my car?
      You're right, I've seen a dustless job that warped a hood. I called them because they'll come to my property & epoxy for a reasonable $.
      Brian
      I remove paint on exterior panels with 80 grit on a DA and only blast jambs, floors, wheel lips etc where removal with a DA is impossible and the shape prevents warpage.
      Some interesting discussion about these metal prep products is here:
      http://www.spiuserforum.com/index.ph...r-must-read.2/
      Don
