    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 62
      Jul 2017
      SeTX
      LS Swap fuel lines
      Hey guys, I'm in the process of installing a LS2 in my 71 Chevelle. What fuel lines do you suggest or recommend? This is my first LS swap so my knowledge on this stuff is fairly limited. Thanks in advance
      Feb 2011
      dallas, tx
      i used stock lines and Earl lines from the stock line to engine and the same from stock line to tank.
      Dec 2008
      Detroit
      ^^ See above....This is what works
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Aug 2015
      charlotte
      did you guys go with the stainless version or OEM?
      Dec 2008
      Detroit
      Quote Originally Posted by slimjim View Post
      OEM works fine... I used PTFE hose from the tank to the FPR, then FPR to hard line. From the hardline to the fuel rail
      Chris--
      If you need to make hard lines, NiCopp is easy to work with and frames easily. To mate the NiCopp with AN style fittings, do this:
      FL and Calif.
      Thank you Andrew for the tip!
      Aug 2015
      charlotte
      Thats a neat video and a great flaring tool, I was planning on using NiCopp for my brake and fuel lines but wasn't aware anyone was still using these pre-made OEM fuel lines on LS swapped cars, I figure it could save some time. But what is everyone doing about the return line? I haven't found any 1/4" OEM lines
      Dec 2008
      Detroit
      You don't need a return line of you use the corvette FPR, only what it needed will go to the rails.
      Chris--
      Feb 2011
      dallas, tx
      vaporworks system didn't need a return line
      May 2010
      kitchener,Ontario,Canada
      What kind of hp levels can stock lines support
      Ryan Austin
      On Instagram ryanaustinss70
      Jul 2017
      SeTX
      I'll be relatively stock with a cam, ported and polished 243 heads and headers. I expect the engine to get 500hp at the crank so I've heard that I can't use the stock fuel lines....any truth to this?
      Feb 2011
      Quote Originally Posted by claytona08 View Post
      What he said. What EFI HP can you support with the factory steel lines? I believe they are 3/8" ID.
      70 GTO - Alum 5.3/4L80e, 7875
      17 GT350
      Sep 2016
      LA - Lower Alabama
      What are you using for fuel lines?
      What is everyone using for fuel line in your LS swaps? I've never plumbed a fuel system for an EFI engine, so there are some details I'm not sure about.
      Is there a "most common" approach? My first thought was to use hardline from the engine bay to the rear where I'm planning to use a corvette style filter/regulator, but I'm not sure how to make the connections from the hardline to filter/regulator and then from the regulator to the tank. Are AN fittings the easiest route here?
      I'm planning to use a Tanks Inc EFI fuel tank, and I see they have a kit that uses flexible for what appears to be the entire fuel system. Is that twist-lock hose durable enough to use for the full length of the car unprotected?
      Arizona
      Factory 3/8" stainless steel from Right Stuff Detailing. Tank to firewall then -6 PTFE hose with AN fittings to the fuel rail.
      Sep 2016
      LA - Lower Alabama
      Do you have a regulator plumbed in there somewhere? Are you using a return line?
      Quote Originally Posted by AU Doc View Post
      I have a ton of pictures in my Cougar build thread. I like NiCopp for fuel and brake lines. Then I mate that with PTFE AN hose. I use a Corvette regulator/filter in the back and a short return line.
      Chicago suburbs
      I really like the hardline, but got lazy with my car. Used Brown & Miller PTFE line fully the last few times I ran fuel lines. Be sure, whatever lines you use, that they are rated to be used with pump gas at efi pressures.
      Sep 2016
      LA - Lower Alabama
      Quote Originally Posted by another69 View Post
      Those are two of the main things I've been wondering about. EFI fuel pressure and ethanol fuel blends.
      Yeah, and whatever you do, DON'T use braided rubber!! It bleeds fuel vapors like a sieve. If you park your car in the garage like I do, the entire garage will smell like raw fuel all the time.
      1971 Camaro
