    Results 1 to 20 of 24
      Feb 2011
      Southside Machine Tall Spindles
      Anyone have any experience with these?
      http://www.ebay.com/itm/NEGATIVE-ROL...dXC17u&vxp=mtr
      70 GTO - Alum 5.3/4L80e, 7875
      17 GT350
      Feb 2011
      Or these -- https://www.cachassisworks.com/p-121...-spindles.aspx. I'm looking for a geometry correction solution (that doesn't require $2000 in hardware) for near-stock applications.
      17 GT350
      Hmmm. wonder what the SIA is on these?
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Jul 2017
      Lincoln, NE
      Lawrenceburg, TN
      Quote Originally Posted by Interceptor5588 View Post
      I am testing these now ...and so far work very well
      Lawrenceburg, TN
      that's the Fatman/ridetech spindle re-branded
      Nov 2002
      Georgetown,TX
      I might have those spindles on the front of my 70. Do they have any identifying markings on them?
      Oct 2007
      Georgetown/Austin, TX
      Rod, do you know if these spindles have the steering arm mounting points moved for bumpsteer correction?
      Jul 2013
      St. George, UT
      While we're talking spindles, don't forget to look at the original geometry correcting AFX spindle that Speedtech manufactures. It's 2" taller, has about a 1" ride height drop, has relocated steering arm mounts for better Ackermann and less bumpsteer, are lighter forged aluminum, use C7 heavy duty sealed bearings that won't blow seals or need maintenance servicing, will better handle the abuse of track days and the load of wider tires and will outlast those factory small muscle car bearings, the spindles have integrated C-5 Corvette brake brackets so you can bolt right on anything from a C-5 factory dual piston caliper up to any aftermarket 6 piston kit. To run bigger brakes on many of the steel spindles you have to buy new brake caliper brackets and have your factory disc brake rotors machined down to hubs so you can use the 13" or 14" slip on larger rotors. After adding up all the features and benefits many would say the extra cost for the ATS spindles is worth the value it in the long run. If that sounds good check 'em out here- Clickey for the ATS AFX spindle web page!
      Oct 2016
      Atlanta
      Rod,
      I have begun working on a basically stock 72 A-body and I know the stock front end geometry on these are, in a word, horrible. I would like to improve the cornering feel of the car a bit even though this one will see hardly any track time. I am calling it a mild build as opposed to something radical. If I understood your earlier post you were testing the spindles (post #5). I am upgrading the bushings through the front end, the sway bars front and rear, going to a slightly stiffer spring front and rear, etc. I was considering using the tall ball joints to help with the front end geometry but have never been quite happy with that solution. Do you have any thoughts on these spindles as part of a mild build?
      Nov 2002
      Georgetown,TX
      The Speedway and Southside Machine spindles look identical. If so, would either be a good unit for an A-body that might never see a race track?
      http://www.speedwaymotors.com/G-Comp...ars,80737.html
      Nov 2002
      Georgetown,TX
      Feb 2011
      Quote Originally Posted by Ben@SpeedTech View Post
      So It appears that the AFX spindle would be the best on a true Pro-Touring build, while the other tall spindles are better suited to a Restomod. Is this about right, Ben?
      17 GT350
      Jul 2013
      St. George, UT
      Well, you might say the AFX spindles are good for any build. ;) lol!
      As with any build to be fair you have to consider your wants and needs. Is the AFX the ultimate best solution in using a spindle to correct geometry and get the car set up right? We think so. If I were a person looking only for the pro touring look and drive a little on the serene side, the AFX would be overkill and I might never take advantage of it's true potential. You mentioned correcting geometry without a $2000 price tag, so based on that the AFX will be at the top of the list of fitting what you're after and has several added bonus features and benefits all other spindles do not have. Hope that puts it in perspective a little better.
      If you have any questions about them feel free to give us a call, 435-628-4300 we'll be straight up and open about whether they, or any of our products fits what you're after. We won't pressure you to buy, just lend insight to help you make your decision. Good luck!
      Nov 2002
      Georgetown,TX
      Ben, I would buy the AFX spindles in a heartbeat but by the time I purchased the needed steering arms, tubular control arms, C6 brakes, and coilovers, the total would probably be pushing $5K or more. Unfortunately, my budget just won't allow it, right now. I haven't given up on the idea,though.
      Nov 2016
      Sulphur, La
      Is there any hard data available that shows camber gain and bumpsteer numbers with the AFX spindle? My case is a 69 Camaro and would like to compare the spindle to the Tru Turn setup.
      Nov 2002
      Georgetown,TX
      Rod, can you give us an update on the S-M tall spindles? I'm trying to decide between them and ridetech.
      St George Utah
      Quote Originally Posted by CSG View Post
      if you can provide some variables then we could do some new testing, the info i have is old and not very understandable (form back in the day)
      i would need to know what ride height you want to run.
      what caster and camber settings you want to use.
      what steering arms
      what static toe setting do you want to use? toe in or toe out?
      stock sub frame?
      whose control arms?
      all of these play a roll in the outcome. there really is no one fix. i can set it up and make the numbers say just about anything you want.
      especially bump steer. ride height caster and camber all affect bump steer. an then what number are you looking for? would you like to to bump in or out? how much?
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Nov 2016
      Sulphur, La
      6 deg caster
      -.4 deg camber
      open on steering arm
      Toe-in 1/8"
      stock sub frame
      I would love 0 bump but prefer bump out over in
      stock geometry arms
      St George Utah
      6 deg caster
      -.4 deg camber
      Toe-in 1/8"
      stock sub frame
      stock geometry arms
      i will need to know the length of the steering arm that you are using as well as a ride height location say the centerline of the lower control arm
      bolt. if you are wanting zero bump you will need a bump steer kit of some sort and a good bump steer gauge, as well as a weekend of measuring and BEER!! also the wheels you are using could become the limiting factor on the stet up ?? but you wont really know till you get there.
      Blake Foster
      435-628-4300
      St. George Utah.
