    Thread: Vision wheels
      Jan 2009
      NYC
      Vision wheels
      anyone have any info on fitment or product on these wheels and suggested tires size on a 66 pontiac tempest with full SPC suspension and Currie rear
      https://www.summitracing.com/parts/v...sb38/overview/
      yes it does have positraction
      Jan 2009
      NYC
      anybody
      Nov 2002
      Georgetown,TX
      6" backspace on an 8" width wheel is a lot for a GM A-body car. Something in your car's chassis set-up that requires it?
      Jan 2009
      NYC
      sorry not following what you mean
      Mar 2012
      South florida
      If you are running a stock setup then 6" backspace will make the wheel sit in too far
      Jan 2016
      Torrance, CA
      Hey, I also am shopping for wheels and tires for my '66 Tempest. You're gonna have to find a tire size you want, then see what offset/backspacing you need to make it fit. On my Tempest with UMI suspension, the outside face of the wheels should stay where they are, the inside has room for width. As you increase the width, you increase both the offset and backspacing. Check out https://tiresize.com/wheel-offset-calculator/ to see what you can do.
      The size I've got now is 225/70r14. That puts them about 26" tall and 8" wide. I believe the wheel is either 7 or 8" with zero offset, not totally sure.
      I want to keep the front diameter the same and use a taller diameter in the back both to add rake and better fill the wheel well.
      The max tire width I can fit in the front measures out to about 295, the back could be 315'ish-- but after talking to the fine folks on this forum, I've decided to go square and to be less ambitious with width. I'm now planning for 275 width all the way around.
      The diameter (tire height) I am trying to stagger. By looking on tirerack, you can enter a combo of different sizes for front and rear and it'll tell you what matches. https://goo.gl/egkpFT
      Once you find a pair of tires, that calculator above will let you enter an offset until the tires line up like you want. Now you're looking for a wheel that's exactly the size you want.... which is hard to find.
      Anyways, that's been my journey. At first I picked out wheels I liked on American Racing but then I started caring about staggered diameters and trying to keep an equal contact patch front+back.
      Good luck!
      1966 Pontiac Tempest
      Two-door, no post. Fixing things one-by-one. Daily driven when it's not up on jackstands.
      UMI Stage 4 suspension. Manual Z06 brakes from Kore3. 275/40r18 and 275/40r19 rear. Currently building a Pontiac 400 stroker.
      Jan 2009
      NYC
      i currently have a 16" Stock GTA Wheel (rear wheels) on all four corners those wheels are stock 16x8 with 5.25 back space if i remember right and my tires are 255/55 all around as well with no rubbing and its lowered with a full SPC suspension i do wish i had the shorter 12 bolt chevy rear from 66 but mine is a dec 66 rear that happens to be longer so i do not see that a 6" backspace will be a problem
