Results 1 to 20 of 21
Thread: LS3 525 vs cammed 430
06-16-2017 #1
I've decided to go with a LS3 for my '55 Chevy. I'm having trouble deciding between the LS3 525 or the LS3 430 and doing a cam swap. It looks like if I do a cam swap it'll get me closer to 570 hp. The ASA cam is 226/236 @ .050 with .525 intake and exhaust and 110 lsa. There are a couple different cams I'm looking at, TSP for example, and they are around 230/245 @ .050 and .630/.615 lift and 112 lsa. I'll be running a close ratio T56 and have 3.70 gears and will be running a 335-345/?/20 tire. The rear end is new and I would like to use it, but not totally opposed to a new gear set to get the perfect combo.
I want the car to make as much power as possible with out sacrificing reliability or excessive wear on the valve train. I want it to be fast when I push it, but want it to be able to take long road trips. It needs to be daily driver reliable. I'm just trying to find the best compromise.
Any other cam recommendations if I go with the 430?
