    Results 1 to 15 of 15
      Sep 2013
      Country Flag: Finland
      tr6060 reverse solenoid
      Hi, im in the middle of swap and going to road test in next week or so. I have original ecu and wiring in place and just curious that will the lock out solenoid work or do i need to make wiring to get my reverse on? I have not tried it yet and this came up in my mind... I do not have any clutch switches etc on my car.
      Does the ecu control the solenoid or do i need clutch switch also?
      If i need wiring to make it work can someone tell me how to hook them up? Is it +12 volts to the other wire or does it need ground to work?
      I have e38 ecu and engine and trans are from 2013 camaro
      The solenoid needs both power and ground to activate, which will allow you to get into reverse easier. I don't know what you mean by this:
      "I have original ecu and wiring in place"
      Are you saying that you have a E38 from a 2013 Camaro? Was there a plug for the reverse solenoid on your harness? If you have the VSS and the solenoid wired to the ECU, I think it should work. Stock programming energizes the RLS below 5 mph.
      Sep 2013
      Thats what i ment, so it should be working correctly then gonna test it tomorrow!
      Feb 2011
      dallas, tx
      Sep 2013
      the reverse is a real bitch to put on...i have to use force to get. Sometimes it goes smoothly and sometimes its really hard to get it on reverse. I have skip shift eliminator in place, could that do something?
      Jonesboro, Arkansas
      I just wired my reverse solenoid to my brake lights. Meaning I have to have my foot on the brake before I can put the car into reverse. Works really good though!
      Carl Wilson
      Dec 2010
      Fredericksburg, VA.
      I wired my reverse lock out to a momentary button in my shift knob. I depress and hold the button with my thumb while shifting to reverse, works great. The solenoid needs +12v and a ground to actuate. I know a lot of people wire the solenoid to the brakes but that causes the solenoid to be activated every time you depress the brake pedal regardless of whether you are shifting to reverse or not.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Sep 2013
      I wired my reverse lock out to a momentary button on the shift knob. I depress and hold the button with my thumb while shifting to reverse, works great. The solenoid needs +12v and a ground to actuate. I know a lot of people wire the solenoid to the brakes but that causes the solenoid to be activated every time you depress the brake pedal regardless of whether you are shifting to reverse or not.
      that kind off button system is really cool! Gonna fab something like that also! Thanks for the info!!
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by minendrews68 View Post
      I did that at first. It activates the rlo solenoid too much, and going 6 to 5 in cases like coming off the highway it would allow a shift miss with associated grinding. Now i have a momentary switch under the dash.
      Scott from NJ.
      Vent Windows Forever! ...
      Dec 2010
      Fredericksburg, VA.
      Quote Originally Posted by timopajala View Post
      Here is the shift knob I'm using but just do a search for "Line Lock shift knob" and you will come up with tons of shift knobs with buttons.
      https://www.speeddawg.com/pro-white-...ck-nos-button/
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      Jonesboro, Arkansas
      After Steve told me about this, I think I may have to go this route as well.
      Carl Wilson
      Sep 2009
      Ontario, Canada
      I wired mine into the brake switch with a toggle switch in series mounted to the console. Toggle switch must be on and brake pedal pressed to shift into reverse.
      Duane
      '74 AMC Javelin AMX
      Jan 2016
      not to hijack the thread or change the subject, but what kind of car is this going in? just wondering because of the lack of a slip joint on the tr6060
      Sep 2013
      it is already in my 1967 camaro and driveshaft is custom made with sonnax adapter and build in slip yoke.
      Jonesboro, Arkansas
      Hey Steve, Just got my shift knob in this morning. I would've had it on by I was too busy baby sitting my grand son. That's ok though.
      Carl Wilson
