      Jun 2015
      Knock sensor real close to header. Is this a problem? with pics.
      I am doing a 80 trans am LS swap with a 2014 L96 vortec. I am using all the HOLLEY swap LS kit. The headers are 1 7/8 tubes.
      the headers are real freaking close to the knock sensor. Will this be an issue with false knock ?? thanks
      Chicago suburbs
      You can loosen the bolt on the sensor and rotate it to help. Then maybe dimple the header and add a heat sleeve
      Quote Originally Posted by another69 View Post
      ^^^This. Just loosen it and rotate it out of the way.
