    Results 1 to 20 of 23
      Feb 2012
      Mocksville, NC
      Drivetrain vibration
      Around 45-55 I get a nice intermittent vibration. Checked the pinion, tranny, and engine angles and they seem to be correct. I have solid u-joints with no zerk fittings but I am running a front motor plate bolted to brackets and welded directly to the frame. Have not had the car over 55 as I am chasing a GV overdrive bug. This car is noisy and shakes and everything is brand new. Could the rotation of the crank be the source since I have no motor mounts?
      1968 Charger R/T, EFI,SC,6-speed
      Sep 2011
      Southern Ontario
      What rpm are you at when it happens? What if you get on the gas? Hold steady? Shift to neutral? Rev it to that rpm in park?
      Feb 2012
      Mocksville, NC
      RPM's are around 2200 and it's a steady, intermittent drone. Have not done a test in neutral. Gonna try that today. Thanks
      It is entirely possible that engine vibrations are going to the frame and causing this.
      Apr 2017
      Lakeville, MN
      If the vibration is speed dependent, it is likely something in your driveline or wheel/tire package. If it's RPM dependent, you may be able to feel the vibration when the car is sitting still by just raising the RPM to the point where you've felt the vibration.
      Driveline vibrations can be difficult to diagnose, but the first place to start would be to make sure your driveshaft is straight and properly balanced. We actually use different width E-Clips to retain the u-joints which will move the joint side-to side slightly when balancing ours and it does make a big difference. If you installed the joints yourself and haven't had the driveshaft balanced afterwards, that very well may be the source of your vibration.
      Bill Foley
      Technical Sales and Support
      [email protected]
      952-985-6371
      Feb 2012
      Mocksville, NC
      Would I be able to see the driveshaft vibrate if I tested the car up on jackstands? Or would this be an internal thing and I wouldn't be able to see it?
      Apr 2017
      Lakeville, MN
      No, I highly doubt that you'd be able to see it vibrate if up on jackstands. Your best bet would be to take the driveshaft (complete with U-Joints and slip yoke) to local shop who does driveshaft work and have them check the balance. Before you do that, make sure your pinion angle is correct. It should match the angle of the slip yoke. Tremec has an app for smart phones that can help show you your driveline angles.
      Bill Foley
      [email protected]
      952-985-6371
      Sep 2011
      Southern Ontario
      So does it do it at 2200 rpm in park? 3000 in park?
      Next, I would drive at the 2200 rpm zone and then shift to neutral and get off the gas, what happens?
      Feb 2012
      Mocksville, NC
      Appreciate the help. Gonna play with it this weekend.
      Jonesboro, Arkansas
      Does the car have this "drone/vibration" sitting still with the motor running?
      Carl Wilson
      Feb 2012
      Mocksville, NC
      No, only at speed.
      Feb 2007
      Tinley Park, IL
      Quote Originally Posted by J-440 View Post
      What do you mean by intermittent? Does it come and go consistently as you're going down the road at 2,200 rpm?
      I'm dealing with something like that right now, according to the Tremec app, the U-joint angle at the trans was off, but the pinion angle was good. I installed a new trans mount with a space, which lifted the trans about 0.25", that change made an improvement but the pulsing vibration is still there. I'm going to re-check my angles and hopefully one more spacer to lift the tail of the trans a bit more will fix it.
      Nick ~
      1969 Cutlass
      Mountain Springs, Texas
      What kind of trans mount do you have? I would expect some vibration with an engine plate and no motor mounts.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Feb 2012
      Mocksville, NC
      Yes a pulsing would be another word. I revved it to 2500 in neutral and there is no vibration so now I'm assuming it is the driveshaft. The tranny is a stock mount. Downloaded the TREMEC app and am going to do some diagnosing.
      Feb 2011
      dallas, tx
      If your cruising say 65 mph and bairly touch the gas does it Humm and vibrate then? Bairly touching as in almost resting your foot on the gas
      Feb 2012
      Mocksville, NC
      Can't get it over 50 and don't want to push it. It's a very loud pulsing noise and when I let off the gas the noise stops at 40mph. So only in between 40 and 50 mph.
      Sep 2011
      Southern Ontario
      So what about 2200 rpm in first gear going much slower?
      Feb 2007
      Tinley Park, IL
      There is a noise along with the vibration?
      Nick ~
      1969 Cutlass
      Oct 2011
      Montgomery, AL
      I just had driveline vibrations once I got up to about 60-70. I had the tires balanced and it didn't cure it. I checked my pinion angle and it was one up. I put in some 2 degree shims and removed the isolation pads between the leafs and axle. Almost all the vibration is gone and the car seems to handle better. My pinion is now 3 down. If that did not work for me my next move was having the driveshaft inspected. Do you feel the vibration in the seat of your pants or the steering wheel?
      Josh Gillis
      68 Firebird
      Pontiac 400 w/ Edelbrock heads, T56, Hotchkis 2" coils with DSE 2" leafs.
      Feb 2012
      Mocksville, NC
      The vibration/pulsing is right behind/below me. I've got a buddy with a lift and a digital angle finder. Shouldn't be too hard now. Going by the angles in Kyle Tucker's pro-touring bible, the engine/tranny should be -3* and the pinion -1.5* for my suspension setup.
