      Nov 2012
      Colorado
      LS1 head gaskets and studs
      I have a 2004 LS1 that I am going to swap the 241 heads for a set of ported 243's. What head gasket should I be using and do I need to replace the head bolts or convert to studs?
      Any help is appreciated..
      thanks, Jeff
      Quote Originally Posted by 32deucecoupe View Post
      thanks, Jeff
      I believe the LS6 used MLS gaskets. I would use those...As for bolts or studs, that is up to you. Studs are better, but for a mild build, there is nothing wrong with using stock or ARP bolts.
      Nov 2012
      Colorado
      Andrew,
      Thanks for the quick reply, when you say stock do you mean new stock type or reuse the same ones I took out.
      Thanks again.
      Andrew,
      Thanks again.
      New for both head gaskets and head bolts.
      Nov 2012
      Colorado
      Thanks buddy...
