    Results 1 to 20 of 20
      Feb 2017
      Price Quote from a builder question: Too high???
      Hello,
      My name is Andrew and I'm about to begin the second chapter of a pro-touring build. I know what I'm about to ask is a very difficult question to answer but I want to pose it because I'm afraid the price quote I was offered is a bit high.
      I own a 1976 factory 400 4 Speed car. Single owner car. Rust free. 32,000 original miles. Numbers Matching car.
      In 2008 I had a four link, 8 point cage, Strange Rear end, Rear Brakes, Interior completely redone and mini tubs installed for approx. $15,000.
      I've recently decided to start the next chapter and will be having the following things done:
      1) Discard everything forward of the firewall (motor, front sub frame, transmission, wheels, suspension, brake booster, radiator) (THROW OUT EVERYTHING)
      2) Replace factory front sub frame with Detroit front sub frame
      3) Replace factory body mounts with solid body mounts
      4) Add in weld in Detroit Speed sub frame connectors
      5) Discard driveshaft
      6) Strip car of all fuel lines, brake lines, factory gas tank, exhaust, exhaust hangers, clips, clamps (EVERYTHING UNDER THE CAR EXCEPT for the 4 link rear suspension and brakes
      7) Wire brush, prep, seal and paint entire under side of car.
      8) Add new/gas tank (OEM style)
      Assuming I purchased and paid for all parts (including the new tank, frame, connectors, body mounts and hardware)......how much would you be willing to spend on the LABOR for this? I guess the better question would be how many MAN HOURS should I be expecting?
      I would post what I was quoted but I'd like un-aided opinions so I don't skew your take on this. I'm curious because the quote I was provided was including a very vague write up and before I drop off the car and before I sit down with my builder I'd like to have as sound of an opinion as possible.
      I need to add in that I've already removed the fenders, hood, inner fender walls, interior carpet, seats, belts and center console so the builder doesn't have to worry about that!!!
      Thank you,
