    Results 1 to 15 of 15
      Jul 2013
      Grayslake IL
      Brake Bleeding/ Pressure Problem C5 Brakes
      Hi guys, having a real frustrating problem with the recent brake conversion on my 1986 Monte Carlo. I have upgraded the front brakes to a complete C5 front setup. It has C5 calipers, rotors, pads, umi conversion brackets, wilwood hubs, and stainless flynbye lines. The rear brakes are stock drums (will upgrade after getting new rearend). Ive tried beeding my brakes the manual method with someone in the car pumping and me at the bleeder opening and closing. This method worked great for the rear drums and fluid flow was great and all the air came out of the rear lines. Moving to the frront, after the pumping and hold method I open the bleeder on the C5 caliper and little to no fluod dribbles out...I did some research and discovered that I had th calipers on the wrong sides of the car (bleeder screw down instead of up) and switched sides with the calipers and assembled everything again. Tried bleeding the brakes again after this swap and still little to no fluid dribbles out. I was getting some air bubbles flowing out very slowly but there is still little to no pressure coming out. I have a brand new wilwood master cylinder on the shelf so I bench bled that master thoroughly and installed it onto the car. I wanted to verify that the master was not the issue s thats why I swapped this on. It bench bled perfectly and connected the car just fine with no leaks. But i am getting the same issue, the drums bleed just fine but the fronts still have very little pressurre. Im stumped and would like to know if you guys have any insights. Thanks guys.
      I always tell others to take the high road, that way there's more room for me on the low road
      Erik Peterson
      1986 Monte Carlo SS Build Thread: https://www.pro-touring.com/threads/...6-Nascarlo-2-0
