      Chicago suburbs
      How much cooling is really needed?
      LS3 swap into a 1st gen Camaro. Dry sump oil, DSE rack. With my original SBC setup and Unisteer rack, I ran a simple aluminum radiator with a single fan, and an external plate & fin engine oil cooler. The motor never got too hot, but the steering fluid got above 200- even with a small air to fluid cooler.
      My question is will the same radiator and engine oil cooler that kept my 425ish HP Gen 1 SBC be enough to cool off my dry sump 500 HP LS3? The other question is, will I need a cooler with the front mount DSE rack?
      Thanks.
      Quote Originally Posted by another69 View Post
      Thanks.
      I think your existing radiator should be fine. If your steering fluid is getting too hot, then I suggest a bigger PS cooler.
      Chicago suburbs
      Ok, I was looking at C&R stuff, and they make a fluid to fluid power steering cooler that fits inline with a radiator hose. Maybe I will just add that? Their radiator modules look really nice too. I'm just not sure if I would want to go fluid to fluid with the engine oil cooler in case of a leak... but it would simplify things.
      For now maybe I will just add the steering cooler, assuming it is needed with the DSE rack.
      Lawrenceburg, TN
      if you autocross or track the car you need to cool everything, My car has a separate oil cooler, and a power steering cooler both with their own fans, and completely apart from the radiator
      Chicago suburbs
      I do track the car, just not often enough!
      How hot is too hot for steering fluid?
      Nov 2012
      Colorado
      Rod, What do you run for a radiator and fans? yours is an LS set up isnt it?
