    Results 1 to 14 of 14
      SF Bay Area
      Leaf Spring Advice- First Gen Camaro
      Hi All,
      I have a 67 Camaro with the full Hotchkis kit. 2" drop springs in the front, 1.5 drop in the rear. After i set the car down initially a couple of years ago when I installed everything, the rear was too high. I ended up throwing some 1" drop blocks in there to correct it and make the stance right. At this point, i need to pull the rear end apart for some other upgrades/changes, and i want to replace the leaf springs with 3" drop so that i don't have to run spacers to get the ride height correct. So, here's my question. Is there any advantage to the Detroit Speed leafs over the Hotchkis? My first inclination is to go with Hotchkis since everything else is from them, however, i can't seem to find a set that doesn't include hangers, u-bolts, and other stuff i don't need. They are also $490 vs DSE's $385, probably due to the extra parts i don't need.
      So, $100 obviously isn't a huge deal on a project of this scope. Should i just stick to Hotchkis for the springs to match everything else, or are the DSE springs better? Anybody have any experience with both?
      Thanks in advance,
      BK
      May 2015
      Island Lake, IL
      Whichever you choose, I'd say chase down a spherical spring eye and adjustable shocks to get the most performance from your leaf spring. Pro-Touring F-Body is another option you should consider since they specialize in performance leaf spring suspension.
      Sep 2015
      Rockvale TN
      Most vendors will sell you individual components from kits even though they are not advertised...give them a call.
      Appleton WI
      Quote Originally Posted by HandOverFist View Post
      This.
      Jim
      1968 Camaro --502HO, ATI 10" TreeMaster, Hughes TH400 with Gear Vendor's OD, Moser 12-bolt, RideTech StrongArms and MuscleBar, Chris Alston G-bar rear suspension, 2 1/8" by 4" Lemon's Headers through 3" Pypes X-pipe and Hooker AeroChambers.
      May 2015
      Island Lake, IL
      Global West also offers springs with no bushings.
      May 2015
      Island Lake, IL
      Global West also offers a front/rear spherical spring eye kit with Del A Lum frame bushing. This would probably make the rear of your car settle slightly more due to it sitting on a bind-free bearing instead of bushings.
      Part 115sh from GW
      Pro-Touring F-Body also a bolt-in leaf spring slider kit that gets rid of the standard shackles and will lower the car.
      Jun 2006
      Katy,TX
      You could also get your springs de-arched if they are working OK for you. Look for spring companies that do truck springs.
      1965 GTO project car
      2004 Pulse Red GTO
      If you like the rate, can you reverse the spring eye to get the drop you want?
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Newbury Park, CA
      Hotchkis also offers a heavier rate spring with more drop and a front spherical bearing. With the Fox tuned shocks it rides surprisingly well.
      Nov 2014
      Lake Worth, FL
      Did you ever pull the Hotchkis Rear leaf springs off the car?
      Do you have them available for sale?
      thanks
      Scott
      Mar 2013
      Sunny Calif
      Dse vs hotchkis rear leafs
      currently running hotchkis 3" drop rear leaf in vert 68 - advertised 150-180 rate with tuned fox shocks and is excellent on a controlled surface, road coarse, strip and canyon carving
      Real world daily driver duty: train track crossing, intersection dips at posted speed limits, with or without a full tank of fuel WILL bottom out.
      Not an issue if you are expecting it and really like the look as a trade off to the bottom outs ratio but can jar your fillings loose from time to time.
      Am currently looking to upgrade to pillow bump stops to soften the blow and replace rear shackles +1.5" (roughly .5" height gain) car looks a bit low at times in the rear although it measures exactly the same at all four corners (just a preference not to gain any measurabe amout of travel)
      Contemplating swapping out to DSE 2" drop 175 rate spring pack.......any trades out there?Name:  2.15.18.jpg
      Check out the Cat 5 Leafs from Global west.
      I have the 2" drop ones on my firebird.
      Apr 2013
      Moparcolt, sharp looking bird, can you provide any details on the wheel and tire sizes. Great stance, Excellent color choice and a beautiful car overall.
      Tim john---
      Jan 2003
      Arizona
      Before you do anything, loosen up the rear shackle bolts and bounce the back of car a little. Make sure your shackles are not bound up...
      ________________
      Steve Chryssos
