    Results 1 to 11 of 11
      Dec 2014
      Murfreesboro, Tennessee
      Backspacing question.
      Hey all. I have a question. I am looking at rims. Year One with 17x9's are set with a 5'' backspacing. It was either car craft or hot rod that said I can put 17x9.5's on the car with a 6 inch backspacing. My question is if I split that number to 5.5'' backspacing I should still be good.
      Car is a 71 Firebird Formula. Global West Suspension all the way around. Thanks for yalls time.
      Ben
      1971 Firebird Formula 455HO 6 speed
      2017 GMC Sierra Denali Ultimate Pearl White 6.2L
      2013 GMC Sierra 5.3 6 Speed Pearl White, SLP 1.9L Supercharger(Sold)
      Dec 2014
      Bueller? Bueller?
      Apr 2012
      Woodstock, IL
      How will you split the difference to 5.5" if the YearOne wheels are 5"?
      SchwartzPerformance
      Oct 2016
      Kansas
      Unfortunately, this also depends on what tires you will be using? On my G-body 442, with a factory 15x7" SSIII with a 4" BS on, I have 1.7" from the rear lip to the frame. So, my 18x9.5s I am ordering with only a 5.25" BS which combined with 275/40s sets the wheel/tire exactly in the center of my fender well. I am going 17x8 up front with a 4.5" BS to set those wheels exactly in the center of the front wells with 245/45s on them. This is all without any spacers which I won't run.
      Always better to put a stock wheel on knowing its BS and do some number scratching. That said, a 6" BS would not even go on my 442 and 5.5" BS would put the tire right on the frame.
      Obviously, if you are lucky to find someone on here with a 71" Formula . . . they may have the calculations already done.
      Dec 2014
      Quote Originally Posted by Schwartz Performance View Post
      Hot Rod mag or car craft says 17x9.5s with a 6 inch backspacing fits.
      Canon. I can't put the stock wheels on the car. Brakes are too big. I'm gonna run 275 40 17's. Yea. There's not too many of us formula guys. Everyone wants a T/A.
      Aug 2011
      Connecticut
      One way to figure out if they fit is to use a tape measure, Obviously its easy to just ask questions and hope someone knows. . . But the better solution is to just do the work yourself and learn.
      1967 Firebird "Poor-Boy Build"
      New updated thread
      https://www.pro-touring.com/threads/...bird-(Updates)
      Follow me on Instagram @NaturalLivingMan
      Apr 2012
      Woodstock, IL
      Ok so what are your wheel plans? 9.5 or 9?
      It sounded like you were looking at getting YearOne wheels but they aren't available in 5.5" BS.
      Too much BS and you'll rub the inside. To little BS and you'll rub the outside. A 9.5" with 1/2" less BS than you referenced will be .
      1/2" closer to rubbing the fender.
      I know this doesn't exactly answer your fitment question but just trying to understand what you're trying to achieve.
      SchwartzPerformance
      Dec 2014
      With a 17x9 rim I would need a 5 inch bs. 17x9.5s a 6 inch bs. I found a deal on 17x9.5s with a 5.5 bs which split the difference between the two. I would measure with a used tire, but 275 40 17's are not to be found here in Montana.
      Jun 2006
      Indianapolis,IN
      If a 6 inch BS fits with out issue then a 5.5 on a 9.5 wont work. If your clearances are tight with a 9.5 a 1/2 is a lot to move in either direction.
      Dec 2014
      Quote Originally Posted by PRRC View Post
      17x9 with a 5 inch also fits.
      Dec 2012
      9" rim with 5" backspacing has 5" "frontspacing" = 0 offset
      9.5" rim with 6" BS has 4.5" FS = +.75 offset
      9.5" rim with 5.5" BS has 5" FS = +.25 offset
      So, if the first rim doesn't hit, then the third one shouldn't hit either, but this is dependent on sidewall bulge.
      Found a clearance comparison calculator online. I ran a quick simulation of your situation, but it could use better data points if you have them. Also, they calculate backspacing wrong, just add 1/2" to whatever they report.
