      Sep 2013
      Country Flag: Finland
      2013 camaro tac module?
      Does 2013 camaro have tac module or is it tps system that sends the info To pcm and then To throttle body? Im doing swap and have the original harness etc and need little More info about the electrics.
      Oct 2006
      Morristown, NJ
      I don't believe that the later controllers have TAC modules. I believe that the DBW is controlled by the CPU.
      1973 Camaro Type LT/RS
      http://www.apiem.com/camaro
      The Gen IV electronics don't use a TAC module. There is a plug right off the ECU that goes to the pedal.
      Sep 2013
      Thank you very much for the info! That clears a few things By the way, is the overflow tank pressurised or not? Im thinking of using my old reservoir but it dont held pressure.
