      Oct 2007
      New Tampa Area
      Help with Brake Master Cylinder Selection
      Hi, I have a 67 Dodge Dart which weighs around 3000 lbs with the following:
      Front: 245/45 17 tires with Dodge Viper Calipers
      Rear: 315/35 17 tires with Mustang Cobra Calipers
      5-1 pedal ration.
      Mopar 1.125" piston master cylinder (manual)
      I would like to stick with a manual master cylinder if possible.
      Can someone recommend what would give me good braking? Currently on test drives its scary!
      Darin
      Without doing the math, you need more line pressure, which means a small bore MC. Try 1995 Dodge Spirit with manual brakes. That's a 7/8" bore MC. O'Reillys sells one for about 60 bucks with an aluminum body and plastic reservoir.
      Oct 2007
      New Tampa Area
      Thanks Andrew,
      I will pick one up and let you know how it goes.
      Darin
      Oct 2007
      New Tampa Area
      I installed the 7/8" bore MC and the braking is much better.
      I want to re-bleed the brakes again this weekend and then see if it can lock wheels.
      Darin
      Glad it seems to be working out.
      Sep 2014
      AZ
      never mind I just read the Ron Sutton sticky.
      Dan
      Quote Originally Posted by Dannnn View Post
      Dan
      Dan,
      Ron's sticky is a good read, but realistically, most people end up with either a 15/16" or a 7/8" bore MC when going with manual brakes, given a common 6:1 pedal ratio...
