      Melbourne, FL
      Electronic temp sensors.
      Are all temp sensors the same?? I potentially will have three different sensors. EFI temp gauge and fan controller. So my basic question is will one of these be able to control all three items?? Hope this makes sense.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Melbourne, FL
      Well I found a possible help. I was also using my stock idiot light for my water temp. But have discovered that I can get the same version of my water temp gauge i was going to use that has a built in warning light. I can do the same with some of my other gauges. So I will no longer need to worry about warning lights for my gauges/functions.
      Temp sensors generally work by varying the resistance at different temperatures and thus the signal can't be split to multiple devices.
