Brake boost and a vacuum pump engine
I have a 2nd gen f-body running a 700hp Pontiac motor that requires a vacuum pump. I bought Willwood 6P Superlites for the front and 4P for the back with 14" rotors but now have to get a master cylinder and booster. I'm considering the hydraboost option but don't want to blow money that I could be used elsewhere. The build has a DSE Quadralink, T56 Magnum, so it should put some power to the ground effectively. I'm wanting the braking to be the most reliable setup. There's a lot of bling under the hood so I want to also have something that looks good, though function is by far the most important requirement.
I need to finish the brakes and fuel lines to make it a runner. Already painted, etc. Still have some interior work to do but the braking system is my priority now. As a second question, should I run hand made lines or buy from InLine tube, given the master cylinder will not be stock? I don't mind buying a nice bender if that is what it takes but I want the cleanest look possible.
