Results 1 to 20 of 27
Thread: Tremec Question
11-08-2005 #1
Tremec Question
I have a tremec 3550 and it has a vibration that starts around 2500 and lasts until 3-3500. I am sure that it is in the tranny as it is present at these rpms regardless of gear.
The vibration is slight at this point and un noticeable for the first 30 minutes or so of driving, especially now that the temps have dropped. I was wondering if there would be any harm in running a higher viscosity oil instead of the synchromesh fluid recommended. My logic is based on that when the tranny and fluid are cold, and thicker?, that it adds some cushioning to the tranny.
Any thoughts as if this would work? Will the thicker fluid cause any damage?
I realize someday, a rebuild will be in order down the road, but would this work for a few year depending on milese traveled and driving habits?
11-09-2005 #2Did you change your pinion angle when you installed your 5 speed? Did you lower the rear of the trans to eliminate cutting the tunnel? It also could be universals, out of balance driveshaft, worn pilot bushing, mis-aligned bellhousing, etc? What did you change/replace for this installation?
Originally Posted by Jeremy
Using a thicker/heavier gear fluid to help minimize vibration is not fixing your root cause. Dig, dig, deeper!!
Regards, JodyJody Haag
[email protected]
Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
610-413-8015
Jody's Transmissions on Facebook
11-09-2005 #3Jody,
Thanks for the reply.
To install the tranny, I cut the tunnel as needed to get the necessary clearance. I have checked and re checked the driveline angles and am sure that is not the problem.
I have a new aluminum shaft from Denny's driveshafts.
I have a rebuilt rear end with new moser axles.
I have a new centerforce flywheel and clutch.
As I have read more on the installation of tremecs, I did not measure the runout relative to the center of the crank shaft. I have a factory bellhousing.
The vibration is totally dependant on the input shaft speed (engine rpm) as it is present at 2500 to 3500 regardless of vehicle speed.
I would not be suprised if the bellhousing is off a bit and wore out the input shaft bearings as I understand now that this is what can happen if the alignment is off. If just correcting this will lessen the vibration until I can have the tranny checked, I will by all means pull the tranny this winter and correct it. I realize whatever damage is done will not be un done, but if it will help, great.
I know that 50 weight will help a older motor smooth out and run a little longer before the rebuild, and was hoping the same held true for a tranny.
I have also noted that second gear is hard to shift into, especially on the 3 to 2 downshift. Up shifts are fine.
I hope this helps.
11-10-2005 #4After your driveline is warmed up to full running tempeture, do you have a reverse gear crunch?
[email protected]
610-413-8015
11-11-2005 #5I am not sure what you mean by a reverse gear crunch. If you could explain I would appreciate it. This way I will for sure know what you are referring to.
11-11-2005 #6
