    Page 3 of 3 FirstFirst 1 2 3
    Results 41 to 58 of 58
    Thread: Life sucks...
      Mar 2015
      Anaheim, Ca
      Double post...... Whoops
      JORDAN
      Jun 2010
      Deployed
      The gear ratio in the rear did not blow up the transmission. Like mentioned critical speed of the driveshaft, driveline angle, bad u-joint were likely factors in my opinion. Not to discount something is the trans itself failing causing the internals to lock up. A full tear down might show that
      1970 Camaro/DSE build
      I have 4.33 gear in my Cougar with a T56 and 27" tires. Rubber engine and trans mounts and a double CV CF driveshaft. At 75mph the driveshaft is spinning 4000rpm, so it is critical to make sure that all driveline components are aligned properly. The front and rear operating angles should not be more than 3 degrees (max!!!), preferable as close to zero (but not zero) as possible.
      Mar 2015
      I love your car so much. What wheels are you running now?
      Aug 2010
      New Albany IN.
      Thanks man. They are cheap ass XXR's lol heavy but cheap...
      Mar 2015
      By chance where is your tuner located? Im not to far away.
      Aug 2010
      New Albany IN.
      He is in Clarksville Indiana Rob Raymer
      Feb 2011
      dallas, tx
      i have yet to get my car on the highway but im running a 315/30/18, t56 magnum, 4.11 gear setup.
      Aug 2015
      NJ
      Quote Originally Posted by icemanrd19 View Post
      Ha! I am (will be like you) running that same set-up (T-56 Mag/4:11 Detroit Locker in a 9" - tire size still in the air 335 or 345)
      Previous set-up had a M-22 with 12bolt 4:10 - Loved it! Most fun I have ever had driving. Yes it sucked on the highway no doubt, but highway trips for this country boy were far and few. Why do you need to do 200mph when a ticket over 85mph can put you in the passenger seat for a while? I never got a ticket for accelerating too fast - just sayin'
      Mar 2015
      Any updates? Are you running 2nd gen mirrors ?
      2014 ZL1
      Aug 2010
      New Albany IN.
      I just ended up buying a 6 speed out of a 05 GTO. So far so good. And yes those are 2nd gen mirrors
      Sep 2015
      what did the 6speed cost you from the gto?
      Aug 2010
      New Albany IN.
      Right at 1300
      Sep 2015
      Quote Originally Posted by corvettekid1973 View Post
      Right at 1300
      Thats a damn good price, can't find that around here.
      Aug 2010
      New Albany IN.
      Thanks ������I honestly have no clue how wide it is. Its a 9 inch that was already in the car when I got it.
      Reading, PA
      Were you using the cast iron slip yoke?
      Jody Haag
      [email protected]
      Most 4, 5, and 6 Speed Repairs, Parts, Service & Custom Installations
      610-413-8015
      Jody's Transmissions on Facebook
      May 2001
      Mesa, Az.
      I'm not sure why all the 3.73, 3.89, 4.11, talk. Each of those is only about 100 rpm difference from the next one...Not a big deal at all. I've run all those gears in front of t56's. Never had issues like that from driveshaft speed. Like Andrew said. Get it all balanced right and pick your cruising RPM. Done.
      Phillip
      69 RS Grille to your 68, Camaro
      I hope you are still on the forum because I need your knowledge about using the 69 RS grille and headlight assembly on my 68. Please reply to me about your success with pictures. Or you can email the pictures and give me a call. My name is Larry Thompson and my member name is monarch packaging. I am a new member with no experience locating anything so if you know of other guys that helped you, please send me those posts. Thanks & Blessings, Larry, 559 688 7308 Home and Office, or 559 978 0625 Cell.
