    Results 1 to 12 of 12
      Indiana
      LS3 dead throttle (drive by wire)
      So yesterday I finally have everything attached and ready to go so I turn the key and the LS3 fires right up, rpm goes up for a second or two and then it settles down to a nice idle! Awesome! So I blip the throttle and nothing happens. I try again, still nothing.
      Full disclosure - To get the pedal harness through the firewall without creating a huge hole, I cut the connector off. Once all the wires were through the firewall, I shortened the harness (it was about 3' too long) and reattached the connector. Simple enough, red to red, blue to blue, etc.
      Because I have a Holley mid-ram intake, the throttle body harness was too short to reach. About two weeks ago I ordered a 12" extension from Lingenfelter thinking I would have it soon. I got tired of waiting so I spliced in wire to make the TB harness long enough to reach the TB. Again, simple enough, red to red, blue to blue, etc.
      Naturally my first thoughts are I caused the issue, but after looking around online, a dead throttle pedal seems to happen occasionally. So I bought a scanner and I got two codes (but each one comes up three times).
      P0107 – MAP or Baro circuit low input
      P0641 – Sensor reference voltage “A” circuit/open
      Would anyone happen to have a wire diagram showing what voltage should be on what pin for the throttle body and pedal?
      If you have any ideas or suggestions, it would be greatly appreciated.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      May 2010
      kitchener,Ontario,Canada
      I'm lost ...but paying attention to this
      Ryan Austin
      On Instagram ryanaustinss70
      Indiana
      List what ECM and pedal you are running, did they come from the same vehicle? Each ECM has an operating system in it to run with a certain pedal/throttle body. Give me some details and that will help
      Aarik
      68 Camaro LS2/T56, Jake's Rod Shop C6 Subframe, JRS torque arm. Ridetech TQ Shocks
      Herb,
      If this turns out to be a pedal issue, I have a CTSV pedal for sale (cheap). It's the same pedal that GMPP sends with their ECU and harness kits.
      One thing to double check is that if the harness was insulated that the sheath is properly grounded. I forget how GM does it, but when Holley sends out a DBW harness they have explicit instructions not to alter length. This isn't because there is something magical about the length but because most people will not ground the cable insulator properly.
      Dec 2014
      Check for VREF at pedal. I am thinking that you may have lost your 5v VREF. Possible shorted to ground somewhere.
      Indiana
      Quote Originally Posted by Hugger67RSSS View Post
      Aarik, it's an E67 that came in the GM Performance kit along with the pedal, harness and sensors.
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Indiana
      Herb,
      Hey Andrew, I'll keep the pedal in mind if it comes to that.
      The harness going to the pedal and the TB are wrapped in the metal sheathing. When I shortened the cable to the pedal, I pushed the sheathing back up the length of the wires until the connections were done and then I was able to pull it back down over the wires like GM had it. On the TB side I used the excess wires and sheathing I cut off the pedal side to lengthen the TB harness. I wasn't thinking about the sheathing needing to be grounded, but I did make sure to overlap the sheathing for what I assumed was EMI protection.
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Indiana
      Quote Originally Posted by ford396 View Post
      I did that last night and I got 0v on all pins at the pedal. A friend suggested that since I have a code for the MAP, that I unplug the MAP and see if I the throttle works. His reasoning is that the reference voltage is shared by the various sensors and if the MAP is bad and/or grounding, it could stop the pedal from working. It's an easy way to check it so I'll give it a shot after work.
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Indiana
      Herb, I know you may not need to but I also have a Corvette pedal you can try if needed. Since it's all of the stuff from GM in a matched kit you obviously aren't trying to mix and match it like some people do so my thought shouldn't be the issue.
      Aarik
      Dec 2014
      If unplugging MAP does not get your VREF back, then check to see if you have VREF at MAP. If you do, then the PCM is putting it out and you likely have an open circuit to the Accelerator Pedal Position Sensor (APP).
      Indiana
      Well I fixed it!
      When I passed the wires for the gas pedal through the firewall, I shortened them as I mentioned in my opening post.
      Each spliced wire got heat shrink around the connection. Once all the connections were made, I slid the metal sheathing down over the spliced bundle. Then I put a single piece of larger heat shrink over the entire bundle to keep the wires together and also to keep the metal sheathing in place.
      Apparently when the large outer heat shrink shrunk, it must have shrunk so tight that any sharp points on the connections pushed through the inner heat shrink and made contact with the metal sheathing causing a ground situation (I only figured this out by doing a continuity test on each pin). After I pulled the bundle apart, I wrapped some electrical tape around each one, and suddenly the throttle worked!
      Now I need to get back in there and clean things up so this doesn't happen again!
      Thank you everyone that replied and offered suggestions!
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
      May 2010
      nice .....glad to hear you got it fixed and it wasnt terribly hard to figured out ....go drive the hell out of it now
      Ryan Austin
