    Results 1 to 9 of 9
      IN/MI border
      Clutch pedal loss at high RPM
      Have roughly 500hp motor mated to LS7 pressure plate and disc. Ran a couple track events without issue. Last year I had the tranny out for motor reasons. At next rack event I noticed clutch pedal loss on the track to the point I couldn't shift up or down after making a lap on the track running the car at high RPM. Once slowed down on track predal came back, same if I pumped the pedal. It didn't get spongy, it just went lower to the floor. I had since replaced the stock LS1 master for a Tilton. When getting on the car hard here locally I've noticed a slight loss of clutch pedal again. My fear is I'll have issues on the track again.
      In doing some more research I ran across a post discussing this exact issue taking place with the LS1/LS6/LS7 clutch with "self adjusting pressure plate". Has anybody heard of this or had this issue? Not a big fan of pulling the tranny back out if I don't have to.
      Here's the link I found.... see post #8
      http://ls1tech.com/forums/manual-tra...hydraulic.html
      Just want 2nd opinion before I spend more $$ I don't have.
