      Jun 2015
      San Diego
      Best LSX hi torque mini starter
      i'm looking at 3 starters my LSX 454 67 Camaro build and wanted to ask if any members had any good/bad experiences with any of these;
      1. MSD mini starter part #5096 http://www.summitracing.com/parts/msd-5096
      2. Powermaster mini starter part #9509 http://www.summitracing.com/parts/pwm-9509
      3. Hitorque mini starter part #IMI140 http://www.hitorque.com/Gear_Reducti..._p/imi-140.htm
      the hi torque is the most expensive at $400 but was highly recommended.
      thanks
      Kris
      Quote Originally Posted by KB Camaro View Post
      thanks
      Kris
      Kris,
      Why not save a bunch of money and just get a stock starter? The 5th Gen Camaro starters are about $110 from Amazon. They also have a neat heat shield that can be bolted to it and the solenoid connector is a nifty little plug that can be bought and makes for a clean disconnect. Depending on your bellhousing you may need to clearance the inside of the bell a little. I use a 4th Gen Fbody T56 bell and it only took about 10 minutes with a Dremel and a little flapper wheel to make it mount cleanly. Details in my Cougar build thread.
      Santa Clara, CA
      I have the MSD on my LSX454 and don't have any particular issues with it. I'm still working the bugs out of my install so I can't give it a glowing recommendation because I do have a hard-starting problem but I also have a small Braille battery in the trunk and 1 gauge cabling and that might just not be cutting it. I have a new optima that I'm going to replace the Braille with and see if that changes my situation. But I don't think any of my issues are starter-related. Mine is also a few years old, just before they were re-branded as Dynaforce, not that that matters either, I believe. Good unit.
      Steve
      Jan 2013
      Cypress, California
      "Why not save a bunch of money and just get a stock starter? The 5th Gen Camaro starters are about $110 from Amazon. They also have a neat heat shield that can be bolted to it and the solenoid connector is a nifty little plug that can be bought and makes for a clean disconnect. Depending on your bellhousing you may need to clearance the inside of the bell a little."
      This is the route I went with my LS3 based 427 and it has worked out just fine. Plus the starters are available anywhere.
      Same here: I've talked with several folks with issues with aftermarket starters on their LS motors. Factory is the way to go, I believe.
      ​John Parsons
      Apr 2012
      Woodstock, IL
      If I had to choose, I'd choose powermaster.
      If your compression isn't above 12.5:1 then a stock one should last you a while, especially if it's EFI.
      SchwartzPerformance
      Jun 2015
      San Diego
      thanks for all the feed back guys!
      is this the GM piece y'all are referring to?
      http://www.officialgmparts.com/oe-gm...rtgaAi_c8P8HAQ
      Jun 2012
      I had good luck on my big engine with the MSD. The stock ones would not live.
      Stock comp stuff I use stock starters
      Tim
      86 Mustang
      454 LS3 Mast 4500 intake FTI cam Holley EFI Drag radials and pump gas 9.24 143.73
      79 Z28 Bonspeed GT-B DSE front and rear Z51 Brakes 5.3 Holley EFI Vintage Air
