      Feb 2006
      Arizona, Phoenix area
      T56 Magnum & LSX Block
      ran into a problem when i went to install my tranny....after several attempts we discovered that he input shaft where it starts to taper out into the splines bottoms out on the pilot bearing... the pilot bearing was mounted flush with the crank but does have room to seat further back. it measures about .200" interference, simple fix is to just push the bearing back but its not what we did with the old school chevy stuff so i'm now guessing, anyone have this experience? Or do i need to start researching if I got the wrong input shaft or bell housing?
      Dec 2010
      Fredericksburg, VA.
      In case you missed it, this is the "Automatic Transmissions" section.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Austin, TX
      But to answer your question, there are 2 different pilot bearings. 1 mounts flush to the trans the other is deeper. You need the deeper one. I ran into the same issue.
      Sep 2017
      Yeah I wanted the flush bearing it's bigger.
      And I wanted to run the LS9 clutch. And a Tilton TOB. I lacked .500 for the fit and another .125 for the air gap on the Tilton.
      So I machined a .625 steel spacer between the trans and bell housing. Quick time
      It fits nice. It's. On my build thread if you need a look see
      Jason's 67 pro touring camaro build
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
      Dec 2008
      Detroit
      Quote Originally Posted by TANKMASTERJ View Post
      Jason
      The last update to this thread was 5yrs ago....
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
