      Jun 2014
      72 chevelle LS swap
      Hello, everyone I'm new here. I have a question that I'm sure has been asked before several times but cant find an answer. I hope that anyone here can help me. I have a 72 chevelle that I'm swapping to Ls engine. My question is, is there any Ls engine and automatic trans combo that I can use without modifying the trans tunnel? Thanks in advance.
      Quote Originally Posted by Hari2629 View Post
      Yes, see here:
      http://ls1tech.com/forums/conversion...m-preview.html
      Jul 2011
      Nashville/ Tampa
      200-4r will fit, can keep the same driveshaft too
      https://www.instagram.com/gen_v_lt1_chevelle/
      Do not buy anything from Frankie's Used Auto Parts. Ever.
      Chevelle ̶a̶l̶m̶o̶s̶t̶ ̶f̶i̶n̶i̶s̶h̶e̶d̶ L92/200-4r now Gen V LT1 and T56- https://ls1tech.com/forums/conversio...nvertible.html
      Mar 2013
      The answer depends on the specific engine mounting set-up you use and the resultant engine positioning they provide. With the engine/transmission mating plane left in the stock position, you can install a TH350, TH400, 700R4 or 200-4R automatic behind an LS engine without cutting the tunnel; if you move the engine/trans mating plane forward by 1.25", you can also install a 4L60-4L70 or 4L80/4L85 automatic without modifying the tunnel. Moving the engine forward excludes the ability to use the 4th-gen F-body accessory drive in its stock configuration and will require relocation of the alternator to the passenger side of the engine.
      Jul 2015
      72 chevelle LS swap
      4l65 case out of the impala fits no prob
      Nov 2015
      Iowa
      Go with the Holley kit. Trust me on this.
      Source: 1972 Chevelle w/ LSA and 4L80e
