    Results 1 to 16 of 16
      May 2015
      Island Lake, IL
      Carburetor section on forum inactive
      Been surfing the forum and find it crazy seeing people post LS questions, update builds, talk suspension, and everything else but the carburetor page has threads that are months old with no updates still on the first page. I've made a couple for sale posts or even update my build thread and it gets pushed to the next page within a day or two.
      Is anyone using carburetors on this forum? Maybe all the carburetor people are out enjoying their cars running/driving while all the efi tech guys are sitting on the computer talking about their systems. Maybe there just isn't too much tech to ask about a carburetor...idle speed, mixture screws, jets, air bleeds and away you go.
      Quote Originally Posted by F-Body International View Post
      What's a carburetor?
      Beach Park IL
      Its the thing that puts the fizz in soda pop.
      Donny
      Right!
      I have one of those...
      Aug 2012
      Peoria, AZ
      Quadrajet fan here...
      Just set my new engine up to run with the same Quadrajet...
      Engine builder asked me before the dyno session if I really wanted to run the Quadrajet on this engine.
      After a couple of pulls I asked him back if he still wanted to put a Holley on it? :D
      Lance
      May 2015
      Island Lake, IL
      That's awesome you put together an engine and used a quadrajet. It probably performs well with no hiccups on autocross because the fuel bowl is in the center of the carb.
      Feb 2011
      So CA
      Love my 770 ultra street avenger.
      Jan 2010
      Louisiana
      Quick fuel 850 w/vacuum secondaries here.
      Champagne taste on a beer budget.
      Landon
      67' Camaro
      My Build Thread
      Celina, Texas
      I have a CarbShop/CSU blow-through carb. Does that count?
      Lawrenceburg, TN
      Maybe all the carburetor people are out enjoying their cars running/driving while all the efi tech guys are sitting on the computer .
      yep! here is Suzy rapping our Carbed LS engine car up on the autocross...yep....Carb...LS...autocross...
      Jan 2014
      Portsmouth NH
      I am running an old Holley double pumper on my car still. Figured I would try to do the best I could with it. I have/had it tuned very well for the engine ...that is until I have turned the car more into a handling car. It was set up originally for drag racing so will have to re-tweek it for the rigors of autocross and track days.
      I have already discovered that hard braking will flood the carb and kill the engine. This made me look at the vent system... for now have a hose with a hole on top connecting both vents... seems to help alot.
      Need to look at changing the floats but not sure of what else to do. If anyone has experience with Holley double pumpers tuned to autocross & roadracing...I welcome all advice and suggestions.
      Cheers, Brew
      Loganville, GA
      Brew, roadrace floats will help out quite a bit. Also, the fuel bowl vent whistle helps as well, my Holley Street HP came with them. I haven't had any issue with fuel coming out the vent tubes. Don't set the fuel level in the bowls too high either, of course too low doesn't help either.
      The newer HP style carbs (Holley, Quick Fuel, Demon, etc) do a much better job than the old style Holleys. I find them easier to get them tuned right. But then you have to buy one, so I would work with what you have first.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Jan 2014
      Portsmouth NH
      Thanks for the info Randy. I am thinking about using the Quick Fuel road race float kit kit info here .
      I was also going to replace the redneck engineered hose connecting the bowl vents together with one of these...Avenger crossover tube .
      Do you guys recommend any online shops preferably in the North East that would carry this stuff?
      Dec 2010
      I gave up on carburetors pretty recently--last summer. My last was a Holley Street Avenger, and generally speaking, it worked pretty well. I decided to drink the LS Kool-Aid, however, and part of my decision to do that involved the cost of carb-related parts, along with their relative longevity (not great). You can get a very good, complete LS truck intake, including injectors and fuel rails, on e-Bay for like $150 bucks. I ran out of reasons to use a carburetor (and a Ford small block, but that's another story) . . .
      Aug 2011
      Sevierville, TN
      I'm running a carbed LS! So far, my only issue has been a rich idle. I just recently realized I'm running too much fuel pressure. I'm currently working on installing a pressure regulator.
      750 Street HP
      Matt Kenner
      68 C10 stepside
      If you can leave two black stripes from the exit of one corner to the braking zone of the next, you have enough horsepower. - Mark Donohue
      Oct 2013
      Country Flag: Norway
      Have a 350 with a Qjet. Building a 383 to replace it. With a Qjet on it.
