      Dec 2015
      Ford Fuel tank between custom frame
      Not sure which section to post this in, I have an Art Morrison rear frame in my 63 Falcon, was going to install a fuel cell but would also like to keep a bit of trunk space for road trips, as well as keep the COG of the fuel lower in the car..
      Looks like 60's to 70's ford cars used a fuel tank 32 5/8" wide but because these mount to a flange I assume those measurements are outside dimensions.
      can someone measure the tank on a falcon, mustang, fairlane, cougar etc and tell me if it will drop between frame rails 29 3/4" inside dimensions...if it does then the flange will load directly on the frame rails and make my floor pan fabrication easier..
      thanks
