    Page 4 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 ... LastLast
    Results 61 to 80 of 236
    1. #61
      Dec 2015
      Folsom, CA
      Quote Originally Posted by camrat68 View Post
      Do you have any pictures of the backside of the front brakes and spindles? Also, what is the part number on the rotors front and rear?
      Jim
      I bought the full kits:
      Front - http://www.wilwood.com/BrakeKits/Bra...no=140-12271-D
      Rear - http://www.wilwood.com/BrakeKits/Bra...mno=140-7140-D
    2. #62
      Appleton WI
      Thank You!
      Could I bother you for one more picture-the back brake line and how it connects to the caliper? I'm trying to figure out the rear brake line hookup to the Wilwood calipers. I'm going from stock drum to their disc kit and I'm trying to figure out what I need for axle lines.
      Jim
      Last edited by camrat68; 01-20-2016 at 07:55 AM. Reason: To clear up my confusion. :D
      1968 Camaro --502HO, ATI 10" TreeMaster, Hughes TH400 with Gear Vendor's OD, Moser 12-bolt, RideTech StrongArms and MuscleBar, Chris Alston G-bar rear suspension, 2 1/8" by 4" Lemon's Headers through 3" Pypes X-pipe and Hooker AeroChambers.
    3. #63
      Dec 2015
      Folsom, CA
      Thank You!
      Jim
      I'll take a picture of that when I get it all back together. It's apart right now because of the leak I had. I used 10 inch Wilwood flex lines from the calipers to the bulkhead brackets on the rear axle. Originally I had 90 degree fittings at the calipers but one of them wouldn't tighten up in the right position and leaked so I switched to straight fittings. The lines convert to rigid at the bulk heads through the spring clamp type fittings. I bent and flared the rigid lines from steel line stock. The rear lines I got with the Right Stuff kit wouldn't fit. I ran the rigid lines to the tee fitting just to the driver side of the rear diff and then to the rear flex line to the stock rigid line location. I know a picture would probably make more sense. I should have it back together this weekend.
    4. #64
      Dec 2015
      Folsom, CA
      So far so good on brake lines round two. I got all of the correct parts in during the week and no leaks so far. Below are pictures of the rear brake line routing. I had to make a bracket to bolt the rear tee fitting on. The first tee I had didn't have a mounting hole so I had clamps on the lines. Much more solid now with it bolted to the diff plate.
    5. #65
      Appleton WI
      Thank You VERY much for those photos! I'm still trying to get my parts list together for my Spring Wilwood swap.
      Jim
    6. #66
      Dec 2015
      Folsom, CA
      Jim
      No problem. Hope it helps.
    7. #67
      Jun 2015
      San Diego
      nice build, i can't wait to see the finished product.
    8. #68
      Dec 2015
      Folsom, CA
      Quote Originally Posted by KB Camaro View Post
      Thanks. Me too. I'm not inherently very patient though so maybe this long term project will be good for me. Ha.
    9. #69
      Dec 2015
      Folsom, CA
      The steering is all hooked up. I went with an AGR 12.7:1. I'm getting about 2 1/4 turns lock to lock which might be a little sensitive, but I've read people running that ratio and saying it's great. Not much I can do about it but wait and see. Borgeson has a 14:1 but they are back ordered forever it looks like. AGR has a variable 16:1-13:1 but that's fairly close to stock in the middle and I'm worried it would be too loose. We'll see..
      My rear wheels will be here Wednesday so I'll be ordering the engine and trans this week. The fuel tank and radiator will be in this week as well. I went with the notched tank, fuel system, radiator, and fans from BRP Hot Rod. They sell everything for LS conversion and were really helpful on the phone. I decided to go with the Speedtech engine mounts and Holley 302-1 oil pan though vs. what BRP offers. Their mounts sit the engine a little up and forward and the LH8 GM oil pan sits a bit too low past the cross member for my liking. The 302-1 pan looks like it will give plenty of clearance to the Tru Turn link and won't hang down below the cross member nearly as much - if at all.
      I've also read some get the T56 in without tunnel mods, and some don't. To be safe I'm just going to cut mine and weld in the Chassis Works tunnel cover. It seemed like the cleanest option given that I'm not planning on going with a full console. It will look like stock but give me some clearance for the T56 at the correct drive line angle. Will make it easier to decide where to locate the shifter too.
    10. #70
      Dec 2015
      Folsom, CA
      I still can't post images. Any time I try to upload one, it shows a blank thumbnail and a file size of 157 bytes, but it won't show in the full list of posted images. The last file in that list also shows 157 bytes with no thumbnail but it doesn't show up in any list that lets me delete attachments. I went through all of the settings and don't see anything of use. I sent an email to the forum contact but haven't heard back yet.
      Anyone know how to fix this by chance?
      UPDATE: They got it fixed.
    11. #71
      Dec 2015
      Folsom, CA
      I got my rear wheels yesterday and had tires put on today. Had to run home at lunch and put them on. If I get time tonight I'll put it down on the ground and see how it sits.
      Motor and trans will be here next Tuesday.
    12. #72
      Dec 2015
      Folsom, CA
      On it own feet!! I'm liking it!
      I might need a little adjustment on the front camber huh??
    13. #73
      Nov 2012
      I imagine once you get the engine in it, a lot of that will go away.
      Love the dish on the wheels - nice choice.
      _______________
      1969 Camaro
      1966 Skylark
      1964 Lemans
      1960 Biscayne
      Steve
    14. #74
      Dec 2015
      Folsom, CA
      Christmas in February today!!
      I have everything on hand to get going on mounting the engine/trans so I hope to make some good progress this weekend. I almost had the fuel tank and lines in last weekend but I had a fitting strip out on me and I had to order replacement parts. The tunnel cover was on back order but luckily a forum member offered me up one that he wasn't using so I'm in business. Thanks again!!
    15. #75
      May 2013
      San Diego, CA
      Great progress, subscribed to this one. Let's see some photos of that tunnel welded up, glad you could use it.
    16. #76
      Dec 2015
      Folsom, CA
      I test fit the motor Saturday and found a few problems as expected. The stock LS3 driver's side exhaust manifold hit the power steering pump. I figured it would but I wanted to see how bad it was before I spent money on headers. Also, the oil pan clearance to the frame was too tight. The motor frame stands that were on the car are weird - the driver's side is lower than the passenger so they are probably just a bad mismatch by someone. There were so many variations on those from the factory it's not surprising. Even still, the manifold was going to hit no matter what. I made a few phone calls today and after a while decided to reconsider the BRP motor mounts and mid length headers. That will give me a little more room at the firewall too. It cleared but was really tight.
      The clearance in the tunnel seemed pretty good though. I cut out an opening just for the shifter to start, and had plenty of room around the front of the trans and bell housing best I could tell. I'll wait for the new mounts to show up before I decide if I can get away with just a top patch on the tunnel or if I need to use the Chassis Works patch.
      I also got the fuel system and the clutch master cylinder in. Those went pretty easy. The tank, pump, sender, line, and fitting kit is from BRP (Tanks Inc. parts). They made it really easy with it all as a complete kit. The clutch master kit is from American Powertrain. Also really nicely put together. I almost feel like I'm cheating with all these full kits available. I would have spent a ton of time and probably wasted money figuring out all the fittings and hardware separately.
    17. #77
      Nov 2012
      Headers will clear that steering box easily. It's been my experience mid-length headers are much easier to manage in this regard. Thanks for the tip on the fuel system.
      _______________
      1969 Camaro
      1966 Skylark
      1964 Lemans
      1960 Biscayne
      Steve
    18. #78
      Aug 2015
      charlotte
      coming along real nice, the fuel kit looks great
    19. #79
      Dec 2015
      Folsom, CA
      Quote Originally Posted by Zoomin View Post
      Thanks for the input on the header choice. That seemed like the way to go for what I want, plus I like the way those look better than the long tube headers.
      - - - Updated - - -
      Quote Originally Posted by slimjim View Post
      Thanks!
    20. #80
      Dec 2015
      Folsom, CA
      I got the motor in with the new BRP mounts. The fit is pretty good for engine clearance. Oil pan is good, clears the Tru Turn steering no problem, and doesn't hang down below the frame. Firewall clearance is better now too.
      The trans fits but the drive line angle is bad in the stock tunnel. I spent a ton of time measuring and trying to mock up the drive shaft line and I'm confident I'll have about a 6 degree working angle on the front, and about 2 in the rear but at the opposite angle from what it should be. Not good and too risky for drive line vibration. I can't adjust the pinion angle anywhere near parallel to the trans. That's what I needed to learn from the initial motor fit though. The solution is to use the Alston tunnel cap I have. It will buy some decent room to bring the trans angle up. The picture below shows cardboard at the line of the cover compared to the stock tunnel top line. You can see how much space it will add. I think it will allow me to lift the end of the trans up 1.5"-2" which should put the drive line at probably 2-3 degrees. So next weekend I'll pull the motor back out and start cutting and welding.
