    Page 2 of 11 FirstFirst 1 2 3 4 5 6 7 ... LastLast
    Results 21 to 40 of 236
      Jan 2013
      Beaverton, Oregon
      This doesn't look like your first car build. Excellent start man. I don't care for the 198 wheels, my vote is ditch them
      That needle scaler is interesting. I've never heard of one.
      Air/Hydraulic tube benders, Drill Press Reduction Kits, Die Sets, Tubing Notchers! All made in the USA
      Dec 2015
      Folsom, CA
      Quote Originally Posted by RogueFab View Post
      Thanks. I guess I wasted my time polishing up the IROC wheels huh? I even shined up the huge screw that's in one of the tires. Oh well.. ha.
      I saw that scaler on another thread about removing undercoating so I thought I'd give it a try. I hadn't head of it before either. Definitely a keeper.
      Dec 2015
      Folsom, CA
      Half way done with the painting. I really hate painting. I made a booth in the garage out of PVC and drop cloths. It definitely contained the over spray but the fumes still got in the house. My wife may just leave me for this one. I had a shop vac pumping air outside or it would have been really bad. I got the under side, sub frame, and firewall done and it looks pretty good. I plan to give the body a once over with the same black just to give me an option of driving it for a while before I have it painted. I ran out of paint though so that will have to wait a few days.
      left coast
      HEADS UP on that metal spray rust repair the stripper did. I'm not an expert, but this is what I discovered recently. Check and see if it's zinc coating. Two big problems, the fumes are very toxic when you're welding around it, be sure to wear a respirator. Second, you can't weld directly on it, zinc has a very low melting point which blows away once you start an arc. Its ugly. How do I know, I had the same process done to a small area to clean up sheetmetal pits that hadn't penetrated through. if you want to weld on it, you have to completely remove the zinc coating around the area you're welding. You can use a heat sink if you're welding near it to prevent heat transfer.
      Dec 2015
      Folsom, CA
      Quote Originally Posted by groho View Post
      Thanks. I knew about not welding on/near it but I didn't know about the fumes. Good to know.
      I only had it done to areas that will be under the glass, that I knew I wouldn't be welding on.
      Dec 2015
      Folsom, CA
      I got the front suspension on this weekend. It went pretty well. I'm happy with the quality of the parts and general design from ridetech. It was a pretty straight forward install but I did have to modify the frame to remove the old bump stops to make clearance for the sway bar links.
      If anyone is planning on doing this suspension setup, make sure you do the sway bar first. The nuts that hold the bar clamps to the frame are blocked by the coil overs. I did it in the wrong order and had to pull it all apart to get the sway bar on.
      Nov 2012
      ridetech is definitely top notch stuff. I've never used their front sway bar, but it sure looks like a great way to go.
      I'm going to school on your thread here - I'm at least 6 months behind.
      _______________
      1969 Camaro
      1966 Skylark
      1964 Lemans
      1960 Biscayne
      Steve
      Appleton WI
      You should've also installed your frame stands for the engine mounts prior to the coil-over installation unless you have REALLY small hands. Also watch your balancer to sway bar clearance throughout the range of suspension travel.
      Jim
      1968 Camaro --502HO, ATI 10" TreeMaster, Hughes TH400 with Gear Vendor's OD, Moser 12-bolt, RideTech StrongArms and MuscleBar, Chris Alston G-bar rear suspension, 2 1/8" by 4" Lemon's Headers through 3" Pypes X-pipe and Hooker AeroChambers.
      Dec 2015
      Folsom, CA
      Quote Originally Posted by camrat68 View Post
      Jim
      Ugh, you're right. Didn't think about that, but I don't have motor mounts yet anyway. I'll either have to get creative or just pull the coil overs back out. Oh well.
      Feb 2013
      Looks great!
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
      Dec 2015
      Folsom, CA
      Quote Originally Posted by Josh@ridetech View Post
      Looks great!
      Thanks! Nice job on the design!
      Dec 2015
      Folsom, CA
      Front brakes are on. This is the first time I've worked with higher end brakes vs. just doing regular brake jobs on stock cars. What a difference!
      Nov 2012
      I'm a big fan of Wilwood stuff. Haven't used anything else since. Great eye candy too.
      _______________
      1969 Camaro
      1966 Skylark
      1964 Lemans
      1960 Biscayne
      Steve
      Dec 2015
      Folsom, CA
      I got tires on my front wheels today. These are 235/45/18 Michelin Pilot Super Sport on 18/8 Foose Knuckle wheels. I had a narrowed down list for wheels and kept going back to these in my searching over a few months, so I decided to try them out. These still have a somewhat classic look to them I think. They have a nice finish and were pretty reasonably priced.
      I only have front wheels so far. I'll use them to size up the clearance in the rear once the suspension is in to see if I can get away with 18/9.5 and 275 on the tires. Crossing my fingers but it seems possible based on what I've read.
      I'm going to start on the rear suspension soon. I got so many boxes from BMR I couldn't keep track of it so I had to lay it all out. They still owe me the actual torque arm. It was delayed a little but is supposed to be here next week. They've been great to work with so far and the parts I have are really nice.
      Nov 2012
      OOOOOooooo what a good boy you must've been for Christmas! Wheels look great!
      _______________
      1969 Camaro
      1966 Skylark
      1964 Lemans
      1960 Biscayne
      Steve
      Connecticut
      Looking really good, just curious since you are using the ridetech with tru turn what made you go with a 8" front wheel?
      Paul Krol
      1968 Camaro
      Dec 2015
      Folsom, CA
      Quote Originally Posted by paulk68 View Post
      The ridetech setup gets you a pretty wide tire up front, but from what I understand the inner/outer fender is still a limiter. This is going to be a street car so 235s are enough up front and I won't have to modify the sheet metal. I also wasn't sure about what width I can fit in the rear (I don't want to mini tub it) and of course can't have wider wheels up front than the rear. They only make these wheels in 8" and 9.5".
      Dec 2015
      Folsom, CA
      Quote Originally Posted by Zoomin View Post
      Haha.. I burned a sizable hole in my credit card on cyber Monday but there were some decent deals going on.
      Dec 2015
      Folsom, CA
      Back to work this week after two weeks off which slowed my pace way down on the fun stuff - go figure. I've made some progress on the rear suspension though. I have all of the components mounted under the car and have most of the parts on the rear end itself. The front to rear brake line is rough fit, but I have to modify it a bit more to clear the sub frame connectors. I bought a pre bent stainless set from Summit which saved a lot of time over doing it from scratch, obviously. I'm able to use everything except the rear end lines, but those will be easy to make. Once those are done and the front to rear line is fit up I'll be ready to hang the rear end and figure out my rear wheel clearance.
      Still happy with the overall quality and fit of the BMR rear suspension but I did have to cut part of the Watts link bracket off of the main support brace to clear an interference with the trunk pan. Not a big deal though and nothing that will impact the strength. It's probably variation on the car and not a design issue with the suspension bracket. They said up front that the brake lines need to be re-routed for the sub frame connectors so I was ready for that.
      Dec 2015
      Folsom, CA
      All of the suspension is in!! Brake lines are in as well and ready to fill and bleed, but I haven't done that yet. I fit up the front wheels in the rear to check clearance and I think I'll be good with the 9.5" and 265/40's in the rear, but I'm going to need to roll the fenders. Good clearance on the inner side. I could have had the rear end made narrow a little in hindsight, but oh well.
      I started researching fender rolling since it's not something I've done before. Looks like the Eastwood tool is the best DIY option but the double layer steel in the rear quarters is a challenge for it. I read that putting cuts every 6 inches or so along the inner lip will help but it's not clear yet if that's going to work out. Anyone have any experience with this on an older car with the thicker double layers in the rear?
      This is the full travel position, with the diff touching the bump stop. Slight side articulation at this height will definitely rub the fender lip towards the rear without rolling it.
