    Results 1 to 20 of 28
      Apr 2014
      Chattanooga
      All Wheel Steering
      So I don't post much, but I'm trying to slowly collect extra ideas for a project without getting overwhelming. I'm trying make an AWD Chevette, and the idea of active rear steering is coming to mind. I'm wanting an independent rear with maybe a Corvette subframe, but that's besides the point, kinda. Again, I don't wanna overwhelm with chassis and suspension questions, but I do have a ton. I've got homework to do, but I'm looking to make a full-tube car with the 'vette shell, and probably an entirely new floor and firewall, given the build goals.
      At first it was an aim for a fully-mechanical system (no TC, PS etc.), engine management aside, and I'm still interested, but that brings me to the question: do I just gut a Prelude mechanical steering system or is there a way to rig something up with GM parts that are out there or? I'm assuming a custom shaft to connect front and rear, but I'd like to avoid electric motors and servos if possible. Electronic transfer cases might change my mind, and I eventually have ABS and the full works in it, but that's way off the mark, I think.
      This isn't a necessity, just an idea. How could it be done feasibly? For chassis design, I'm gonna keep doing my reading.
      Bryan
      Feb 2011
      Indpls, IN
      May 2010
      kitchener,Ontario,Canada
      And the c3 sierras that had it had some very serious electronics and programming to make it function. My question is why ? , with such a short car and a small turning radius doesn't really seem to be something that would be beneficial. Not to mention the gm c3 system came off obviously a much larger vehicle so even if you got it to work. The programming would have to be modified to work with such a small car.
      Ryan Austin
      On Instagram ryanaustinss70
      Birmingham, AL
      Wasn't there a model of the Mitsubishi 3000gt that had all wheel steering?
      Stephen
      Chit-ca-go
      I thought the Prelude did way back in the day.
      1971 Firebird
      2017 Slipstream SS
      The second gen RX7s had passive rear steering. This was done with the use of a special link and bushing at the rear spindle.
      Again, the question is why? Seems that the trouble to make it work would yield questionable benefits and possibly make handling worse.
      Sep 2014
      Before you get too deep, rear steering needs very little travel for anything but parking. Next depending on the speed and turning radius the rear wheels might actually need the steer opposite. And yes a short wheelbase is going to make rear steer even more sensitive, even downright scary.
      May 2010
      on a short wheelbase car that weighs less then 2000 lbs stock and has a turning radius that gm called the smallest in the world 30 feet ,im going to say the idea is cool ,way too involved to use and mainly useless..not needed
      Ryan Austin
      Dec 2009
      Well, there'd be no reason for decrease turning radius steering on a chassis that small, but opposite steer will help reduce the the rotation rate of that car at high speed, which could help it feel more planted.
      By the time it's all said and done a fully mechanical system swap seems like a lot of work for a car that could probably use a different proportionate response rate from most of those vehicles, which means you'd have to modify the mechanics of it to get it to work. I think that diving into a custom controlled electronic system might actually prove simpler at that point.
      There's probably a ton of HICAS systems off the 240sx around, as the mad tyte drift crowd doesn't have much use for it and it adds a fair bit of weight, however it's electronic.
      You know the Corvette Spindles are front steer right? Which means that most of the hydraulic systems won't work as they're based on a rack which would hit the differential. With toe arms up front, you'd want something like the porsche or Acura Individual actuators for each side, which is of course a fully electronic system.
      Apr 2014
      Chattanooga
      It's the Porsche stuff that's selling me on the idea. The high-speed benefits, ya know. I believe their passive rear steer is what Mazda later modified, and nowadays they're using active electronic stuff.
      Quadrasteer would be neat if converted, but I'd have to design a module GM no longer makes just to get one up and running, I'd say. I'm thinking the early Prelude mechanical setup with some hacking up could be adapted, but I'll agree with all the naysayers as well.
      HICAS is a nicer option. The only Corvette bits that will necessarily be used in the build will likely be hubs and a T56, though. The subframe is looking less than ideal for the application, but I'd really like to explore the composite leaf spring thing for space/weight if it can perform.
      Bryan
      Jan 2014
      NY
      I think the Infinity J30T had rear steering
      Dec 2010
      Fredericksburg, VA.
      I gotta say, I owned a 76 Chevette and that car would turn on a dime due to the short wheelbase. I can't imagine one with all wheel steer. IMO, it would be a handful to drive.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      May 2010
      I had a 86 chevette scooter. That was the a"sport" version 2 doors,lol manual steering and brakes, was a joke to maneuver that thing around. Hence why I'm lost on the why?
      Ryan Austin
      Dec 2009
      Did either of you read the bit about counter steering? it's in the thread...
      Dec 2010
      Fredericksburg, VA.
      Quote Originally Posted by ace_xp2 View Post
      Have you ever driven a Chevette?
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      May 2010
      Quote Originally Posted by thejdman View Post
      have you ever driven a chevette?
      lol
      Ryan Austin
      Dec 2009
      Okay, I'll go slower then...
      So Chevette chassis very short right? Makes car twitchy at high speed right? So imagine if you could artificially lengthen the car at speed...
      That's exactly what turning the rear tires into the corner effectively does, it's actually a fairly common set up in all wheel steer systems, when you go fast enough it starts to turn in with you, settling the chassis. That way you can have a small incredibly responsive chassis, which doesn't turn in to a twitchy mess at high speeds.
      Simple enough?
      Sep 2007
      I get your train of thought on this. It's a clever idea, combining a short wheebase + artificially stabilizing it with additional steering.
      I once read that GM played with the idea on a Camaro back around 1990-ish. They found that 1-2 degrees of turn-out (rear wheels turning the same direction as the fronts) produced a measurable stability gain, and 8-9 degrees made the car pretty much uncontrollable. IIRC the later GM truck option only ever moved the rear wheels by a couple of degrees too.
      I have wondered if European WRC Rally cars might be a good usage for a 4WS setup. They are one of the only motorsports that really sees the need for both hi-speed cornering stability + low-speed short radius turning.
      You lost me on the Chevette body, though. I can't see much reason to want one other than the size alone. There are other cooler small cars IMO.
      If you are going for the anti-performance, anti-cool car image of it then I think Chevettes are getting too old. Even uncool cars become interesting-->cool when they are 30+ years old. IMO a busted-ass 1990s Cavalier would fit the anti-performance-car image better today.
      May 2010
      I guess you missed the part where everyone said how complex this would be to achieve?...I get counter steer but the risk doesn't seem like the reward
      Ryan Austin
      Apr 2014
      Chattanooga
      Heh it's only a chevette shell. Tube chassis. I'd mentioned the drivetrain in my intro thread, but it's going to be stupid amounts of power. Kind of a demo car. All wheel drive, as mentioned, and yes, loose surfaces, while remaining street worthy.
      Bryan
