    Results 1 to 20 of 23
      Scottsdale, AZ
      C7 LT1 Engine 69 Camaro
      Please use this thread to update any info for the new LT1 engine.
      Has anyone done a LT1 yet? I scored one out of a project build. I figured I would ask here and share what i’ve learned so far.
      The engine mount bosses are different from the LS series engines. We are going to make our own mounts for my Art Morrison chassis and push the engine back into the firewall as much as possible. I don’t know the actual measurements from where they are as compared to an LS block but will update in the future.
      No engine mounted Power steering as the C7 uses an electric assisted rack. I found a company S&P out of Arkansas that has a full kit for $800. I’ve also looked into an electric pump. The older toyota MR2 unit is a “dumb” pump without all the speed sensor electronics to overcome. However there doesn’t seem to be any real info on if it will actually work. The S&P looks to be the better route for now.
      Exhaust/headers. The exhaust ports are not the same as the LS series engines. S&P makes headers too. Looks like will be buying flanges and designing our own set.
      Bell housing/Engine block bosses are different than the LS series engines. GM offers a LT1 to T56 bell housing that I will be buying.
      Part # 19329620
      The fuel system is unknown at this time. The engine has a cam driven fuel pump to boost the fuel pressure up to 2200 psi for the direct injection. I’m not sure yet what we’re going to do for an in tank pump. I have an older Ricks stainless we’re probably going to mod to make work with a stock style pump.
      Engine mods. I’ve read quite a few threads on the Vette forums and some on LS1 tech. It appears 550-600 RWHP is a reasonable HP number with ported heads/Cam and removing the DOD system. Katech and a couple of shops in Texas look to be the front runners in these builds. So far I haven’t seen any crate builds. All of them have been cars modded and run on a chassis dyno. I’d like to hear more from anyone here who can offer some info?????
      Anymore info out there? Thanks in advance!
      Here’s a pic of the car.
      69 SS/350 Camaro
      AME Front & Rear LT Build
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Sep 2015
      Sub'd to see results!
      1966 Mustang Coupe
      5.0 EFI- T5
      Apr 2012
      Woodstock, IL
      We're doing a 68 Camaro currently, using our chassis though.
      Things we've found so far:
      -The bell housing pattern IS the SAME as the LS. I think the reason GM has a different steel bell housing listed is because their clutch kit/flywheel is huge, like the LSA setup.
      -The wet sump oil pan has less clearance to crossmembers than the dry sump. But the dry sump has a forward drain plug similar to the LS7.
      -Oil pans are different than LS
      -Ultimate Headers should have some flanges/bends in the future for custom headers.. Then headers! Stainless Works makes laser cut flanges currently.
      -The LT1 exhaust manifold outlets (to the cats/exhaust) appear to be the same dimensions as the LS7/9 manifolds. Although I haven't measured.
      That's all for now
      -Dale
      SchwartzPerformance
      Jul 2011
      Washington
      Sub'ed also interested in swapping these shortly
      Scottsdale, AZ
      Quote Originally Posted by Schwartz Performance View Post
      That's all for now
      -Dale
      Dale- I’ve read the bell housing bolt hole at 12’oclock isn’t there on the LT1’s. Is the rest of the bolt pattern the same? Could I cut off the 12’Oclock tab on my LS Quicktime bell housing and use it on the LT1? Will the factory clutch fit in the Quicktime bell?
      Are the dry sump oil pans the same depth in the front of the pan/crossmember area?
      Thanks for the info!
      69 SS/350 Camaro
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Jun 2014
      Any updates on this? First time I saw this thread, great idea. I will be using an LT4 but hopefully some of the information can translate over.
      That's the first I heard about the bell housing as I thought like Cdog said the 12o'clock bolt is shifted slightly so we would need the newer bell housing.
      The clutch and fly wheel should be very similar to an LSA or LSX? Both 8 Bolt but Dale, you said the flywheel is larger than LS? I'm looking to buy the bell housing now.
      ICT Billet has engine mounts to convert from LS to LT that my art morrison chassis has. http://www.ictbillet.com/ls-to-lt1-2...ter-gen-v.html
      Maybe some vendors on here have some up with some new products?
      Apr 2012
      Woodstock, IL
      You'll need to buy the GM Performance bell housing if you plan to run the GM Performance clutch and flywheel kit.
      Companies are working on parts for the serpentine drive, headers, and engine mounts (I see your note about ICT, good info). Not much is available right this moment though.
      I've sold a few LT4's, give us a chance if you haven't purchased one yet
      -Dale
      SchwartzPerformance
      Apr 2016
      Looks like this is the GM part number for the kit. pn 19329912. Fits 8 bolt flanges for LS and LT engines. Rated for 800 ft lbs. Includes bell housing, clutch, throw out bearing ,pilot bearing, flywheel, and bolts.
      Jun 2014
      -Dale
      I don't plan on using the gm kit, I was more planning on using a Tilton throw out bearing with either a centerforce dyad, monster Lt1 or similar twin disc clutches. These should be close to the same size as the gm kit no? The price of the gm bell housing is pretty high compared to a regular ls sfi housing. The only difference in pictures is the two bolt holes at 12 o'clock.
      And for sure I'll give you guys a shout when we get closer to ordering it to get a quote. Might get a quote on the Bell housing from you.
      Apr 2012
      Woodstock, IL
      Yeah if the clutch is a replacement for an LSA or LT then I believe it won't fit under the standard QT bell. But that would be a question for the clutch/flywheel manufacturer.
      We sell the GM one for somewhere around 750, the QT is $625 retail.
      -Dale
      SchwartzPerformance
      Arizona
      Dirty Dingo, Dirty Dingo, Dirty Dingo, Brent has some nice new parts. http://www.dirtydingo.com/shop/index.php
      Scottsdale, AZ
      So the clutch that came on my engine won’t work with a T56 or with the GM bell housing. It’s a hub design that is not compatible with anything other than the torque tube drive shaft.
      I was all excited to see DD came out with an adjustable engine mounts until I called. He said the mounts are designed for a factory frame and had no idea where they would line up on a Art Morrison chassis.
      I’m stalling on the car until some more aftermarket support catches up to the LT1 Gen V engine. Too many roadblocks. I did hear AM is working on a set of engine mounts.
      Good luck!
      69 SS/350 Camaro
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Ontario, Canada
      My other car is a Vega.
      Jun 2014
      Quote Originally Posted by Cdog View Post
      Good luck!
      So your engine was taken out of a C7 stingray? Is the hub design different than the one of the GM Crate engines? Yours is strictly for torque tube? The GM bell housing is supposed to be for specifically for that engine no? Stange.
      Did you to talk to ICT billet about their mounts? Maybe it's the same situation with placement of the engine on the art Morrison. Hopefully Art Morrison figures something out. I spoke with Chris there a few months ago and asked him about mounts for LT4 and he said they were working on them in engineering. Maybe i'll get back in touch with him soon about some updates.
      Scottsdale, AZ
      Quick update. Art Morrison is now in production on engine mounts. They will be about the same as the LS style. Should be available soon. We test fit the prototypes on a 56 chevy chassis.
      69 SS/350 Camaro
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Scottsdale, AZ
      LT1 Headers in stainless steel are available through Art Morrison too. Finally parts are starting to become available.
      Does anyone have any leads on power steering pump mounts out side of S & S? I’ve been told the owner of the company passed away and they’re slowing or stopping production on most of their LT1 parts.
      69 SS/350 Camaro
      69 SS/396 Camaro
      LT4 Build
      71 K5
      Jun 2009
      From Wasilla, AK. Now portland, OR
      check pace performance they have a fead setup now for the lt1 and lt4
      http://paceperformance.com/c-1073953...tems-fead.html
      1970 Elcamino ls3/t56, ricks/vaporworx, sc&c afx ,forgeline zx3, kore3 z51/ls1
      1969 Camaro ls3/t56, ricks/vaporworx, ride-tech,forgeline ga3,
      2024 ford maverick
      Apr 2012
      Woodstock, IL
      We sell the above too.
      Dirty dingo is the only other option I've seen
      SchwartzPerformance
      Jun 2014
      I'm not sure who this guys company is (if there is one) but he's seemed to make one with extra supports on the back. Haven't seen where you can buy it though.
      http://automobileman.com/wp/?m=201605
      Overall it's great to see some stuff starting to show it's face...I see ultimate headers also has part numbers for the LT1 / LT4 with art morrison chassis:
      112021 LT1/LT4 in Speedtech C10 & 1st. Gen Camaro $1,395.00
      112031A LT1/LT4 Art Morrison Tri 5 Chassis w/low profile clamps & 12" extensions $1,403.00
      112041A LT1/LT4 in Art Morrison 1st. Gen. Camaro $1,403.00
      112061A LT1 /LT4 in Art Morrison 64/72 GM "A"-Body $1,403.00
      112091 LT1 in 91-96 Impala $1,195.00
      Taken From:
      http://ultimateheaders.com/new-applications-menu.shtml
      Scottsdale, AZ
      Yep. I called the DD and asked them about fitment of their engine mounts. They said the mounts were designed for stock frames so I passed on giving them a try. One more brand new $100 + part I’ll have to sell here for $50. LOL!
      Are you selling the drive accessories Pace is advertising?
      My engine mounts should be shipping soon. I’ll post a pic as soon as I get them in.
      69 SS/350 Camaro
      69 SS/396 Camaro
      LT4 Build
      71 K5
